instrument panel light
please help my instrument panel (speedo) lights have gone out yet my headlamps are on but no rear tail lights and no fogs either front or back i have checked fuses but they all seem fine can you tell me if there are relays that control these functions and if so which one please thanks for your help Tony
i had this problem, trying to think what it was, it was a simple fix, i think you need to check under the dash there is a control box on the drivers side, if not located fully you lose them lights
as said check under the lower dash on drivers side, as you drop that side there is a module that sits ina holder, make sure the connector is in correctly (all the way) and that its in the holder firmly
Right and side of the wheel, drop the screws out, its located behind the little glovebox thingy, but you cant get to it from that, you need to drop that side unless you can get you hand up and reach
Thank me if im right, because if im wrong, caused you 30 mins work with no gain,
Dont just visual check that connection, physically check it, and let us know
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
