ARGH YOU FU*KING C*NT!!!!!! (Sorted! :-D)
Take the hard disk out, and stick it in the fridge. Meantime, order a new one and when it arrives, get busy getting Windows on your new hard disk.
Spend a tenner on ebay for a laptop USB hard disk box. When it arrives, have your 'new' computer running. Quickly get the cold disk into the USB box. Chances are if you've caught it early enough you may be able to recover most, if not all of your stuff.
Hard disks have bearing in them, which can fail - 'freezing' the drive normally shrinks it just enough to get it to run normally for a few minutes until it heats up again. It's a growing problem in modern laptops as they run so much hotter than they did years and years ago.
Sorry to hear that rad
I doubt it's anything to do with the water splash, hard drives are usually pretty well hidden in laptops. Could just have gone to heaven as they do sometimes.
If you are really desperate to recover your files, there are people out there who do this for a living, do a quick search on the web
Will cost between £100 and £300.
Bit of advice for everyone... Get a 300Gb external hard drive, or bigger. They're only pennies these days.
And backup regularly
Digital photography is great... until you loose all your files
I had a guy with fooked laptop HDD yesterday.
Took the HDD out, used the USB caddy and plugged it up.
Looked at it, it says "The disk is not formatted. Would you like to format it?"
I selected No.
I used an recovery program and it found the dictorary tree and the files fine. So made a full recovery!
So try this route.
I selected No.
So try this route.
I was on the look for an externl HD too! If only I fucking bought one
Cheers though
not the Child Porn Im worried about, Its the pictures from Holidays and my Music...
Fucking gutted if you don't get it back mate.
Its Rads laptop not Robs
PMSL!
Originally Posted by Lee_R21Turbo
not the CHILD Porn Im worried about, Its the pictures from my GAY antics Holidays and my CLASSICAL Music...
Yeah.....I dialed in remotely over t'internet.....copied all his stuff off, corrupted his hard drive & am now holding his data to ransom!!!!
Radders.....you're one sick puppy.....I never knew half of this stuff went on........I see you've got a liking for 'riding' horses!!
misery. i lost mine recently as well. had most stuff backed up on pc though, luckily.
now i have a laptop, a pc, and a NAS where all photo's are backed up to, as well as a reasonably recent dvd
Originally Posted by Smit
Back-up your pictures onto discs Rad...
Simple and easy!
Saving over 26,000 pictures does mean a few discs though
Simple and easy!
upload all your pics to different photobucket accounts
i also lost all my classical music so now resort to old skool garage from the most legalist sources on the internet
sorry to hear about the loss of your porn
its hard to let it go without saying goodbye
http://www.ontrack.com/easyrecoveryprofessional/
get some one to download it for you if you cant yourself... works a treat as long as the hard drive its self is still alive ... if not try the fridge out it does work...
I was going to buy a tape drive to back mine up, then i realised i'd need an ultrium LTO3 400/800 and then realised i didnt have £1200 lying around
Get Ontrack recovery off bittorrent, its what i use at work
works a treat when your allocation table has gone out the window
IBM/Hitachi disk by any chance?
"the click of death"
