Need a measurement.....can anyone help?
Old May 10, 2007 | 09:47 PM
polly_x's Avatar
polly_x
Default Need a measurement.....can anyone help?
Does anyone have cossie engine laying arounf with a clutch and flywheel attached and bolted up? Standard cover plate will be fine.
I need the measurement in mm from the rear block face to the fingers on the clutch cover plate.
Not an easy on to measure I know but must be able to get within a couple of mm by measuring from block to outer edge of clutch cover then take off the few mm that the clutch cover fingers sit in towards the block.
Anyone help?
Thanks in advance.
Old May 11, 2007 | 05:24 PM
polly_x's Avatar
polly_x
Surely someone has a block laying around that they can measure!!!!
