FAO All my customers who are running a wasted spark driver..
Old May 9, 2007 | 07:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default FAO All my customers who are running a wasted spark driver..
As some of you will know, we have had a few problems with the drivers tacho circuit not driving some counters correctly, yet others are perfectly fine.
I would like to build up a picture of what works properly and what does not, so if you could possibly reply here and let me know how the tach performs on your car and what car/tach you have.
So, all i need to see in thsi topic is as follows:
Driver bought: DATE:
Car is: Saff2wd / Saff 4wd/ Escos
Tach is: Std/stack/elliot/ etc etc
Performance: Works fine/slow/1/2 speed...
Engine improvements on ignition side:
Any problems? Missfires? Its better, smoother? Worse?
You will be pleased to know we seem to have found the solution, but want to run all possible scenarions through it before we start to retro fit the solution to all our customers products.
Many Many thanks for your help in this research, and thanks for bearing with us. As promised, we havent forgotten you.
Old May 9, 2007 | 07:45 PM
Rolls's Avatar
Rolls
Default Re: FAO All my customers who are running a wasted spark driv
Originally Posted by Stu @ M Developments
Driver bought: DATE: March '07
Car is: Saff2wd / Saff 4wd/ Escos Escos
Tach is: Std/stack/elliot/ etc etc Standard
Performance: Works fine/slow/1/2 speed... Fine - no mods needed for the rev-counter
Any problems? Missfires? Its better, smoother? Worse? - Will be able to tell you once i've driven the car properly - idle is noticably smoother though
Old May 9, 2007 | 07:49 PM
4x4 ste's Avatar
4x4 ste
My 3 door you have at the moment worked half speed with standard tach, Every thing else worked perfect
My saff 4x4 k6 ssy you did about 12 months ago would sometimes work after a while than sometime not really work at all that was with standard tach. Once again all else was spot on seemed much smoother to drive and never had a problem with it
Steve
Old May 9, 2007 | 08:08 PM
jason 3dr's Avatar
jason 3dr
Driver bought: DATE: 8.2.07
Car is: Saff2wd / Saff 4wd/ Escos (3dr)
Tach is: Std/stack/elliot/ etc etc (std)
Performance: Works fine/slow/1/2 speed... (dont work at all)
Any problems? Missfires? Its better, smoother? Worse . (no problems )
.on second driver ,still not working.used this instead
Old May 9, 2007 | 08:19 PM
Originally Posted by jason 3dr
used this instead
Can you confirm that works fine then mate, as i have tested that personally and it wouldnt work.
Old May 9, 2007 | 08:34 PM
Ryan's Avatar
Ryan
stu i think it only works on 2wd and 3dr, it deffo doesnt work on an escort.
as i've also tried it on an escort and had no joy.
havent personally tried it on a 2wd or 3rd.
Old May 9, 2007 | 08:40 PM
Originally Posted by Ryan
Stu i think it only works on 2wd and 3dr, it deffo doesnt work on an escort.
Was my own 4x4 saff i tried it on as its seemed the simplest and most obvious solution.
Old May 9, 2007 | 08:42 PM
ECU Monitor Enthusiast
Coil dwell overlapping will fool that circuit
JTECH James's Avatar
JTECH James
Passion for Fords!
im quite sure jason is now using a saff rev counter ,with that wiring and it works
Old May 9, 2007 | 09:33 PM
Daveesaunders's Avatar
Daveesaunders
Driver bought: DATE: End Feb 07
Car is: Saff2wd / Saff 4wd/ Escos 2wd Saph (1989)
Tach is: Std/stack/elliot/ etc etc Std - no mod was required
Performance: Works fine/slow/1/2 speed... works fine
Any problems? Missfires? Its better, smoother? Worse? Have a misfire a 2K when engines cold
Old May 9, 2007 | 10:21 PM
Ok, thanks to Simon Johnson for his technical support and Mick Clayton for the loan of his car all day and night, we now have what we hope to be a 100% solution for those people whos rev counters are slow / spurious or just plain dont work in:
Escort Cosworths
Sapphires from 89>
Anycar running an aftermarket tacho.
Unfortunately we cant test a 3door or early 2wd sapphire with this yet so will send out the retrofit solution for now and await their feedback.
Its a very easy DIY mod too. So anyone with problems, contact me on sales@remapping.co.uk and i can fire out the instructions and components tomorrow for Friday delivery.
Old May 10, 2007 | 02:46 AM
Arnie's Avatar
Arnie
Driver bought: DATE: April '07
Car is: Escos
Tach is: Standard
Performance: Works fine/slow/1/2 speed... works ok until 2k rpm,which then halve itself
Any problems? Missfires? Its better, smoother? very slight unstable idle, but that could be due to a leak of vacuum, but haven't really drive it past 2k rpm, dunno what the true rpm is so don't wanna risk it. It does pull cleanly upto 2k tho
Old May 10, 2007 | 08:50 AM
Arnie, i will mail you teh instructions right now as you can probably sort a component locally far faster than i can get it to Hong Kong.
Old May 10, 2007 | 12:50 PM
boXXer's Avatar
boXXer
GASH!
i take it this is not the coilpack conversions? as im after doing this soon.
Old May 10, 2007 | 02:47 PM
Yes, wasted spark is often known as a coilpack conversion.
Old May 10, 2007 | 06:50 PM
boXXer's Avatar
boXXer
GASH!
does that mean you can run smaller gaps with less missfire.... Gunna start a thread. Sorry.
Old May 10, 2007 | 06:52 PM
boXXer,
Yes, BUT, You can run bigger gaps without missfires too which also
improves idle quality and emissions.
Old May 10, 2007 | 06:54 PM
boXXer's Avatar
boXXer
GASH!
Doh, thats what i meant. So in theory, it SHOULD burn better?
Old May 10, 2007 | 06:56 PM
Bingo
Old May 10, 2007 | 07:36 PM
alan rainbow's Avatar
alan rainbow
driver one of the first ones
2wd saff
std taco
no probs
got rid of all miss fire probs
Old May 10, 2007 | 08:17 PM
Big up to STU for giving a shit as a lot don't when they have your money, they run, RESPECT CHAP.
Rodge.'s Avatar
Rodge.
Just installed the wasted spark board in the ECU tonight, not sure whether it will work OK with a MK2 Escort RS2000 revcounter though....!
Not tried it yet - any other Cossie MK2 Escort owners with coilpack conversion here?
Old May 10, 2007 | 08:21 PM
Jasesapphy's Avatar
Jasesapphy
Stu
P8 with wasted spark enabled in the software (not converted wasted spark conversion) doesnt run with a sapph 2wd clock, reads half, but you probably knew that anyway
Old May 10, 2007 | 08:22 PM
Ive not seen a MK2 escort rev counter actually work properly when its still running a MK2 escort engine... so your chances are slim at best...
e-mail me on sales@remapping.co.uk and i can send you the upgrade instructions though. May improve your chances from slim to thin.
Old May 10, 2007 | 08:27 PM
Rodge.'s Avatar
Rodge.
Done, you have email
Old May 10, 2007 | 08:41 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Driver bought: DATE: August 2005
Car is: Saff 4wd
Tach is: Std
Engine improvements on ignition side: Better sparkplug longitivity, larger plug gap (0.8mm on Denso Irridium IK31) and cleaner emissions when tested on an emissions machine
Smoother idle at 850rpm hot with no small "misses" at idle. No misfires in the midrange when the high torque boost spike hits at 27psi - previously with the old dizzy it would miss some days and not others - coilpack cured this. More fuel economy aswell (only a couple of mpg), engine sounded generally healthier aswell (placebo effect maybe?) and the car drove better aswell.
There you go Stu [/i]
Old May 10, 2007 | 08:42 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Rodge.
Expect a parcel in the morning chap - been a long week and today was the only time I could post it
Old May 10, 2007 | 08:53 PM
biscuittin's Avatar
biscuittin
H reg 4x4 saff
taco spot on
idle perfect
best thing i ever fitted on car
Old May 10, 2007 | 09:02 PM
Rodge.'s Avatar
Rodge.
Originally Posted by Graceland
Rodge.
No problem Graceland, no real hurry, had the (unfinished) car for years
Old May 10, 2007 | 09:04 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Rodge.
your address in the "paypal address panel" is the one I was supposed to send it to yes?
Old May 10, 2007 | 09:08 PM
Rodge.'s Avatar
Rodge.
Rodge.
Yes, that's the one
Old May 10, 2007 | 10:06 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Driver bought: Within the last 6 months (Blackpool weekender, minus a month or so)
Car is: Saff 4wd
Tach is: Std
Performance: Works fine following the supplied instructions (the little red wire in the pic, soldered to back of tach)
NO PROBLEMS NO MISSFIRES
Great conversion
Old May 11, 2007 | 07:27 AM
2wd's Avatar
2wd
Driver bought: DATE: 29/3-07
Car is: Saff2wd / Saff 4wd/ Escos Saff2wd
Tach is: Std/stack/elliot/ etc etc std
Performance: Works fine/slow/1/2 speed... seems to be slow and showing only half the rpm..
Any problems? Missfires? Its better, smoother? Worse? sounds better, but not yet tested on the road.
Old May 11, 2007 | 08:44 AM
The DIVA's Avatar
The DIVA
Driver: Old version 1 unit
Car: Escos
Tach: Std
Performance: Fine after mods(see below)
Engine improvements: Random misfires have now all disappeared,can now run larger plug gaps with hard plugs........motor feels generally transformed.....
Mods: I have modified the version 1 coilpack driver and the revcounter as per Stu`s instructions and it now reads ok........did read half revs`s before...
Old May 11, 2007 | 09:01 AM
Disabled Account's Avatar
Disabled Account
Driver bought DATE: 18-10-2006
Car is: Escos.
Tach is: Standard.
Performance: Works fine.
Engine improvements on ignition side: Very mooth throughout rev range, good stable idle.
Any problems? Missfires? Its better, smoother? Worse? No problems.
Old May 11, 2007 | 10:17 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Driver: Version 2 unit fitted during live map in Aug 2006
Car: Saff 2wd running L8
Tach: STACK
Performance: STACK set to 2 cylinder to get correct reading
Engine improvements: No miss fires, wet weather doesn't affect it now
Mods: None other than setting on STACK
Old May 11, 2007 | 10:25 AM
costina's Avatar
costina
Live long and prosper!!
No probs here using on my Tina but using sierra clocks
As always Stu top job
Old May 13, 2007 | 04:46 PM
for the Sunday browsers...
Old May 13, 2007 | 05:41 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I forgot to add on mine Stu, that I had both the revision 1 and 2 drivers on trial in my ECU and both had no tacho problems, except if the core voltage at the ecu dropped below 11 volts (alternator failure) then the tacho stopped working
Old May 13, 2007 | 05:42 PM
the original's Avatar
the original
I'm running 2 of the conversions
standard mk2 escort revcounter reads zero (probably wiring problem though)
standard cortina mk5 revcounter reads half
engine performance good, no misfires
