cossie dizzy help
Old May 8, 2007 | 07:34 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default cossie dizzy help
is a 4x4 cosworth distributor the same as a 2wd one?
cheers
Old May 8, 2007 | 08:40 PM
Stu @ M Developments's Avatar
PassionFords Creator
Physically... NO.
Technically, IE, will it work in 2wd systems? Yes.
Old May 8, 2007 | 08:43 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
u figured out the prob with the motor yet bud ?
Alps Pacino's Avatar
Alps Pacino
so would a 4x4 dizzy phyically fit in a 2wd saph???????????
Old May 8, 2007 | 08:44 PM
Alps Pacino
beefy-rst-2
The motors out again apparently
Old May 8, 2007 | 09:01 PM
Dicko&Vacant
ssshhhhhhhh you hippy boy
Old May 8, 2007 | 09:05 PM
Yes.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
biggiejody
Sep 19, 2015 10:25 AM
