90spec chip in s1 ecu
yeah there's only two wires, but the actual circuit in the ecu is alot more complicated. plus i haven't got a spare sensor to try and the only one i can find for sale is about 50 quid from burton power. quite alot considering you can get an ecu for about 20 quid.
don't think so. i tried bypassing it with a 550k resistor but it ran the same so i think it's the ecu. basically the car holds back when coming on boost. runs ok with the timing advanced. obviously i don't want to run like this in case i melt a piston. there's a chipped s1 ecu on ebay so i might try that. but if my chip will go in then i could get a std one for alot less
yeah but it also has an internal resistance. you can fool the ecu into thinking the sensor is connected by substituting with the correct resistance. the piezo xtal is only active when det frequency is present so the ecu doesn't know any difference. well that's the theory anyway.
hard to say. most knock sensors are piezo resistive and just alter their resistance when det is detected, others are piezo electric and apply a voltage when det is detected. either way when there is no det present is just acts like a resistor. i know it works on other ecu's so i don't see why not.
without seeing the schematics for the rs ecu i can't say for sure. either way if i put a series one ecu in it will cure the problem whether it is the knock sensor or the ecu anyway. maybe i could just use it as a stop gap and fit a megajolt system. seems like a cheap option for 3d mappable ignition.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
