Saff rear speakers which ones?
Old May 6, 2007 | 08:15 PM
jaiscossie's Avatar
jaiscossie
Default Saff rear speakers which ones?
Want some rear deck speakers for my cosworth, what size fit straight in? will 6x9s go in? if not what size is need pls and which make are good.thanks
Old May 6, 2007 | 09:49 PM
xr_craig's Avatar
xr_craig
5.25inch will fit straight in mate, although 6x9's will go in with a bit of cutting
Old May 6, 2007 | 10:47 PM
I put 6x9s in mine n had 2 cut the holes out with a grinder.Ive seen cossies with 6x9s mounted on a piece of wood n then fitted 2 the little shelf where the original speakers go.
Old May 7, 2007 | 08:41 AM
jaiscossie's Avatar
jaiscossie
cheers guys,do 5.25s give a reasonable sound? i guess 6x9s would be alot better sound?
Old May 7, 2007 | 09:54 AM
Well ive had 6x9s in my last 4 cars n i think they sound good.Sound even better when using an amp.
Old May 7, 2007 | 10:07 AM
xr_craig's Avatar
xr_craig
If you are running a sub then go for the 5.25's if not then 6x9's will give a bit more bass than 5.25's. It really depends what your after
Old May 7, 2007 | 10:08 AM
jaiscossie's Avatar
jaiscossie
just after a nice sound really nothing amazing. wont be using a sub want to keep the weight down
Old May 7, 2007 | 10:13 AM
xr_craig's Avatar
xr_craig
I'd probably go for 6x9's then, otherwise you may find it lacks a bit of punch.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
