about the 4x4 front diff and ratios
Old May 5, 2007 | 08:13 PM
coswol's Avatar
coswol
Default about the 4x4 front diff and ratios
some persons sell front diff for 4x4 and say that is for a 3,9 ratio (i understand that is of a xr4 4x4 or similar car) but only with the front diff i have in my sapphire cosworth a 3,9 ratio? or the only way to have it is to change the two pinions and cut the chain of the transfer box?
and in that case one front and rear 3,9 ratios of 4x4 xr4 resist 300bhp of a cosworth?
thanks people
Old May 6, 2007 | 09:50 AM
Sapphire cosworth diff ratios are 3.64:1
The V6 sierra's(4x4) were 3.62:1
Old May 6, 2007 | 10:00 AM
coswol's Avatar
coswol
yes i know it but if i change only the front diff i change the ratios?
Old May 6, 2007 | 10:22 AM
2001ode's Avatar
2001ode
Hi,
You can't change only front ratio (or only rear ratio) : Your central LSD rapidly burn and diff too.
Front and rear ration must be same, EXCEPT if you change in same time the central dispatching ratio between front and rear axles. (2 pinions with chain)
But these pinions are expansive and difficult to find.
Anyway, 3.9 is a very good compromise to obtain good acceleration and good max speed, instead 3.62 or 3.64 stock ratio (2wd or 4wd).
Regards.
Claude
Old May 6, 2007 | 01:17 PM
markk's Avatar
markk
if you put a 3.9:1 rear diff in then i can sort you out with some step offfs (pinions) and chain to match the 3.6 front for your transfer box ?
Old May 8, 2007 | 05:04 PM
coswol's Avatar
coswol
the question is: can i put ONLY the front and rear 3.9 diffs and expect it to work good?
Old May 8, 2007 | 05:13 PM
markk's Avatar
markk
it would work yes.
Old May 10, 2010 | 07:12 AM
Chluppi's Avatar
Chluppi
From what car do I get a 3.9 front diff? Where was it build in?
Old May 16, 2010 | 09:03 AM
dakunia's Avatar
dakunia
Sierra Sapphire 4x4 with 2.0 DOHC engine.
In Your country on Switzerland You should find one without big problems, they are versions for mountain countries...
regards
maciek
Old Aug 19, 2011 | 11:39 AM
seventhheaven's Avatar
seventhheaven
In Development
Hi, I've posted loads of info on the Sierra Front Diff :
http://www.super7thheaven.co.uk/Sier...t_Differential
http://www.super7thheaven.co.uk/blog...ntial-a41.html
There should be loads of info on what cars they come from, part numbers, exploded diagrams etc.
My Sierra 3.92:1 tag reads:
V90BB AA C9P5A CG02It came from a Sierra Sapphire 4x4 GLS 2.0i DOHC if that is of any help.
The FINIS number for the 3.92:1 is 1661121
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
cossie330
Aug 22, 2015 12:00 PM
C2 MAK
Aug 20, 2015 09:46 PM
Old ford
Jul 31, 2015 06:50 AM
