RST Chipped ECU
Old May 5, 2007 | 12:22 PM
AJC's Avatar
AJC
Default RST Chipped ECU
dont know what chip it is, but plugged it up to my mates RST the other night and its never gone so well,
no lie but hitting 24 psi on Mfi.
£100 postd
Old May 5, 2007 | 03:48 PM
lewismk1's Avatar
lewismk1
I can support this people as it was my car we tried them on. A1!!!!
Old May 8, 2007 | 09:52 PM
AJC's Avatar
AJC
Old May 9, 2007 | 04:20 PM
Phil79's Avatar
Phil79
So you just plug it in and get 24psi without touching the actuator or bleed valve?
Old May 9, 2007 | 05:31 PM
AJC's Avatar
AJC
no, but it letss you run that psi, you wont get the fuelling for that much boost on standrard MFi, you will see 16/17 psi though, you can run 22psi, bt you need to upgrade the fuel manaement, or fit a 5th injector
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
griffo69
Oct 4, 2015 11:58 AM
