Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
4x4 Cosworth Straight cut STRONG gearkits
Old May 3, 2007 | 08:44 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default 4x4 Cosworth Straight cut STRONG gearkits
We can now supply tried and tested gearkits for 4x4 Cosworth Escorts and Sierra's. This is how much the straight cut gearset costs....
Gearkit £2650,
1st gear set * £ 250,
Mainshaft* £1000.
All prices are plus VAT
The items marked * are optional and have not been fitted to Porkies car, which at the moment is showing no signs of any problems..This gear box will shorly be removed and fitted to the Mondeo to see how it copes with sustained high speed runs and the effects a heavier car has on it when launching.
You will need a suitable donor gearbox as a base unit for the gearkit to be installed into, if the unit is in good order parts and labour are going to total around £300 (again plus vat).
This means that all in the gearkit built and fitted into your casing and ready to install will cost £3466.25 (based on a good base box)
Any further info needed? Just call 0121 458 6010
IAN RS2k
Aug 18, 2015 07:51 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
