plugs
Old May 2, 2007 | 08:27 AM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default plugs
morning all
was in the garage last night and got my head back on etc. just one little problem left. all the sensors for the head, throttle, metering head etc are all the same size but differnt colours! Does anyone have a diagram or something saying what colour is for what?
Old May 2, 2007 | 10:41 AM
antony215's Avatar
antony215
Escort Rs Turbo
They should be all colour coded to what sensor they go to.
Old May 2, 2007 | 12:14 PM
bassboy's Avatar
bassboy
as anthony said...the sensors on the engine itself should be different colours as well...join colour to colour
bassboy
Old May 6, 2007 | 06:57 PM
RodgeRS_Turbo
ok im just back from the garage. Theres 2 main parts of the loom for plugs - the part that has the plugs for the metering head, amal valve, TPS, charge carrier etc. I got all that sorted out fine,
Its the part for the head im having a bit trouble with. Theres 2 yellow plugs, a black, a green and a blue. One yellow goes into fuel rail, green into right hand side plenum, and other yellow (I think) goes into underneath the plunum next to the fuel line, Ive got the blue and a black left.
Can anyone think what these are for?
Forgot to mention, ive also got another tiny plug that looks round and just clips onto something?? any ideas? ill try and get a pic.
thanks for any input!
Jamie
Old May 6, 2007 | 07:10 PM
Barry R's Avatar
Barry R
the small 1 is for oil pressure the other two i need pictures then i will know
Old May 6, 2007 | 07:13 PM
RodgeRS_Turbo
cheers mate where does it plug into?
The other 2 are just normal plugs like the one that goes into the plenum chamber, for example but one is blue and one is black. They come from the same part of the loom as the plunum chamber, fuel rail etc. Cheers
ill try an get a pic
Old May 6, 2007 | 07:25 PM
Barry R's Avatar
Barry R
follow you turbo's oil feed back to the back of the block it goes into a hex block the small one goes on top and if you get under the front of the car climb to the back of the bay shine a torch about you should see the sensors hope this helps
Old May 6, 2007 | 07:29 PM
RodgeRS_Turbo
cheers mate ill get a look tomorrow
Old May 6, 2007 | 07:34 PM
Barry R's Avatar
Barry R
let us know
Old May 7, 2007 | 08:19 AM
RodgeRS_Turbo
hi mate,
I got the oil pressure plug ok, cheers for your help with that. Couldnt find the other 2 plug locations tho
Old May 7, 2007 | 10:21 AM
gambit's Avatar
gambit
Default black
the black one is tricky to see, but there should be a auxillary air device behind the inlet manifold which the plug has to go on side ways hence maybe you did not see it. It is a little cylinder shaped thing and is grey, the blue i suspect is for the cold start valve and that should be quite visible in the middle top of the inlet manifold (it plugs upwards into the cold start valve) so have a proper look because from above you might miss this sensor..
Thats just of the top of my head so if i am wrong i am sure someone will correct me.
Old May 7, 2007 | 10:53 AM
RodgeRS_Turbo
black one sounds promising mate thanks for that, I did not check there.
I had a yellow one plugged into the cold start valve chances are Im wrong though! If its blue that goes there then I have a spare yellow lol
Old May 7, 2007 | 11:02 AM
gambit's Avatar
gambit
Default plugs
the black one i am 99% sure is right as i told you, the sensor plug is hidden behind one of the big plastic black vacum hoses and goes on sideways. As for the yellow one that plugs in right at the bottom of the inlet manifold in the middle, its hidden so low down and is situated in a recess so feel right at the bottom and you will find that one. its hidden in a recess as i said so hard to see.
the blue one should be cold start matey.
Best of luck
Old May 7, 2007 | 11:06 AM
gambit's Avatar
gambit
Default plugs
as i recall there is one brown one and not two yellows but i have seen some different looms in my time
Old May 7, 2007 | 12:21 PM
RodgeRS_Turbo
you could be right mate, It did look a funny shade of yellow. So far I have got:
Green - right hand side plenum
Yellow - fuel rail, at bottom of inlet in the middle
yellow/brown -
Black - auxillary air device, behind inlet
Blue - plus in upwards into cold start valve, just under throttle
Also if anyone can double check the color of their cold start valve plud id be grateful. Cheers
Old May 7, 2007 | 12:41 PM
gambit's Avatar
gambit
Default plugs
the yellowy brown i think should go where you put the yellow one and then the yellow will go below that where the sensor is quite hidden in the recess i mentioned the sensor plugs upwards into this one iswell and is at an angle not a straight push on.
Old May 7, 2007 | 12:47 PM
RodgeRS_Turbo
makes more sense mate, cheers. I got the 2 yellowy ones mixed up lol
Cheers again, cant wait to get home from work now to get her started!
Old May 7, 2007 | 01:04 PM
SafeChav's Avatar
SafeChav
How do you confuse yellow with brown
As per your PM request i can tell you the CSV is a blue plug without even looking
Old May 7, 2007 | 04:12 PM
gambit's Avatar
gambit
Default plugs
best of luck matey
i swear i woke up with a yellow t-shirt on, but hang on is it not brown hmmmmmmm i cant work it out
just joking mate
Old May 8, 2007 | 08:05 AM
RodgeRS_Turbo
lol suppose I asked for that
I got the black plug in OK, got the blue one into the CSV, got the yellowy brown one into the fuel rail, but couldnt find the one further down for the yellow one - but it was dark time I got home.
Thanks again
Old May 8, 2007 | 10:15 AM
RodgeRS_Turbo
Default Re: plugs
Best of luck
You dont happen to know the name of the device or the sensor do you? I was going to look up in the haynes manual, but dont know what im looking for. Does it actually plug into the inlet or is it below it?
Old May 8, 2007 | 10:29 AM
RodgeRS_Turbo
is it far from here?
Old May 8, 2007 | 10:55 AM
gambit's Avatar
gambit
Default plugs
you have pm mate
Old May 8, 2007 | 11:00 AM
gambit's Avatar
gambit
Default plugs
images removed
Old May 8, 2007 | 11:01 AM
gambit's Avatar
gambit
Default plugs
can you see the yellow one to the right, just lower then the brown one you pluged in???? i think its the one you need.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
