brakes
Old Apr 30, 2007 | 08:32 PM
Gucci Boy's Avatar
Gucci Boy
Default brakes
who has 4pot set up on their escort would like to know if they fit under 16inch wheels
Old Apr 30, 2007 | 10:38 PM
addiction's Avatar
addiction
yes they will fit behind 16's. they will also fit behind 15's as long the wheel design and offset allow
Old May 1, 2007 | 11:15 AM
Gucci Boy's Avatar
Gucci Boy
cheers thanks for the info pal
Old May 2, 2007 | 03:46 PM
scortgti's Avatar
scortgti
wilwood 283mm 4pots def fit under 16's f that helps at all
Old May 2, 2007 | 08:19 PM
NUTS RuS's Avatar
NUTS RuS
16" should see you with at least the 315mm x 28mm ones
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
