Greys.....and fooking fitting em
Old Sep 17, 2004 | 06:44 PM
Ima-Racing500's Avatar
Ima-Racing500
Default Greys.....and fooking fitting em
Fitting the kit has been the hardest part of the engine build
Right so i got the kit on.......the end which sprays only came with a plastic washer a seal and a cap.....now i have it as plastic washer (which is loose on injector but is the perfect size for the inlet manifold) a seal and then the cap....does that sound right????????
Now i have heard run without a cap......no can do or the plastic washer/o-ring would just fall off..the cap actually holds it together in the inlet.So how big to i drill the cap out to????As big as poss??Is that gonna be enuff to give a good spray pattern???
Many thanks.
Old Sep 17, 2004 | 06:45 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Sep 17, 2004 | 06:50 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Forget the greys. Wot turbo did u choose in the end?
Old Sep 18, 2004 | 01:02 AM
gurnE's Avatar
gurnE
Throw the plastic washer/ring away, it's wank and not what you need
Get some standard EFI washers to go above the o-ring, should be able to pick them up at any tuners
Interpro sent me some for mine FOC
Drill the pintle cap out to 3mm or leave it off, the choice is yours
Fitting greys for the first time is a twat cos the fitting kit is wank , once you've done it once tho
Old Sep 18, 2004 | 07:32 AM
Matt's Avatar
Matt
classic post phil
no caps fitted on mine
where exactly do you think the o ring that meets the inlet manifold can fall exactly when its sat flush up to it
Old Sep 18, 2004 | 09:58 AM
Ima-Racing500
Good point Matt!
Cheers people....i think Gurn E the plastic ring will be tried first as it fits in the inlet nicely...if it fooks up will look at the metal washer
So no caps needed.
Ben26
Aug 27, 2015 08:56 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
cameron2
Aug 10, 2015 12:14 PM
