Uprated diffs for a 2wd cossie
What companys do uprated diffs for a cossie ?
Can they make the standard one stronger or is it a complete new unit ?
Any ideas on price as well please.
Steve.
Steve.
Quaife only do a LSD not the full diff.
Its not the LSD part of the dif that breaks so going to a quife wont really make your diff any stronger.
Steve.
Steve.
I dont launch the car but Lee Tib certainly does and Im sure he uses a standard one too.
if you click my car <---------
you'll see the pic of the quaife fitted, and the bits that normally break on a cossie diff are not there
there are loads of options out there though
Steve.
Steve.
hi mate
you have got 3 choices
1, you can have your diff rebuilt with uprated planet gears and uprated Viscous coupling to 240Nm on the standard VC plates (standard VC is 50Nm when it was new)
2 you can have an ATB fitted
3 you can go plated route
no matter which one you go for the crownwheel pinion will be the weakest part you will never break a plated unit it's self ever they are made from EN42 harden steel
marco
Steve.
Steve.
hi mate
marco
Steve.
Steve.
Steve.
hi mate
marco
Steve.
ill get you a price mate
it will be built properly and dyno'ed to make sure it's working properly before you fit it
you can aslo have the CWP shot peened aswell if needed
marco
Steve.
Steve.
hi mate
marco
Steve.
marco
You can PM me the price if you want.
Steve.
Originally Posted by JohnnyB
try and find a granny 24v estate for a cheap option, for some reason Ford needed a lower range diff for the estate and for some reason they are much stronger.
Steve.
Steve.
Steve.
Dan
Originally Posted by SillyFezzaMk1
If you remove the clips and take this section out of the diff then you can put your driveshafts into it....and it will be plenty strong enough for your 24v conversion.
Dan
Dan, if you read my sig the 24v XR4i has been sold
Just got the turbo nutter one now
Steve.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
