sierra front brakes
Old Apr 28, 2007 | 09:59 PM
stevetinks's Avatar
stevetinks
Default sierra front brakes
need to know what brakes will fit a 1.8 j reg sierra. i.e will cosworth or mondeo discs go straight on to the hubs etc
Old Apr 29, 2007 | 06:37 AM
Cossie 4x4 discs and calipers will go straight on.
2wd 4 pots(cossie) will go on with a tiny amount of work, just need to tap out the lug holes on hub to take bolt for 4 pot calipers, holes are already correct size for tapping, then straight on, on some you need to grind away a minute amount of caliper where the spacer is between the two halves.
Old Apr 29, 2007 | 10:56 PM
stevetinks's Avatar
stevetinks
happy days. cheers
Old Apr 30, 2007 | 05:35 AM
No probs, I found on my 2l sierra they were crap tbh, going 4pots was best thing I did.
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
C2 MAK
Aug 20, 2015 09:46 PM
Aug 10, 2015 12:08 PM
