Help (Again lol) - Sick Cossie
Old Sep 17, 2004 | 04:39 PM
Skiman's Avatar
Skiman
Default Help (Again lol) - Sick Cossie
My escort cosworth has a wee problem....
when coming onto full boost and giving it a bit my engine is stalling, no matter what gear...full boost = stall...then after about 2/3/4 seconds it will bump start....
help...
Old Sep 17, 2004 | 04:43 PM
Jamz's Avatar
Jamz
blocked fuel filter ? Knackered fuel pump ?
Old Sep 17, 2004 | 04:44 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
trapped wire?? crank pick up?
Old Sep 17, 2004 | 04:49 PM
Skiman's Avatar
Skiman
u can hear the fuel pump whining a bit, which sounds normal cos my last rs turbo had that aswell....how do u check the fuel filter...
Old Sep 17, 2004 | 05:08 PM
Skiman's Avatar
Skiman
bttt
Old Sep 17, 2004 | 05:09 PM
cossie1's Avatar
cossie1
overboost ???
Jamz's Avatar
Jamz
you don't generally check it, just buy a new one and see if it cures the problem.
Old Sep 17, 2004 | 05:11 PM
Skiman's Avatar
Skiman
I think the boost has been turned down a tiny bit from standard as an old man had it before me.
The DIVA's Avatar
The DIVA
Its overboosting mate either turn the boost down a tad or get it chipped and run even more !!!!!!!
Old Sep 17, 2004 | 05:12 PM
cossie1's Avatar
cossie1
std boost is about 8 psi from memory
so whats it running atm ?
Old Sep 17, 2004 | 05:13 PM
Skiman's Avatar
Skiman
im not 100% sure tho....the overboost hits the first dash, then full boost settles half way round the solid bar on the standard boost gauge.
Old Sep 17, 2004 | 05:16 PM
cossie1's Avatar
cossie1
get a real gauge on it m8 to check it out
Old Sep 17, 2004 | 05:17 PM
The DIVA's Avatar
The DIVA
That sounds like the prob then mate,its prob just on the limit,try half a turn anticlockwise on the actuator............should do the trick
Skiman's Avatar
Skiman
i think the gauge is working fine....so its an overboost problem do you think?how do you sort that one out?
Old Sep 17, 2004 | 05:18 PM
cossie1's Avatar
cossie1
the gauge don't give u a psi reading tho so really u have no idea what boost your running
adjust the actuator
Old Sep 17, 2004 | 05:20 PM
Billabong's Avatar
Billabong
Is the car std or chipped? Don't forget Escort Cossies will 'overboost' as std(shouldn't cut out though) as it was designed to under certain conditions.
Old Sep 17, 2004 | 05:23 PM
Skiman's Avatar
Skiman
the car is totally standard...
Old Sep 17, 2004 | 05:26 PM
phil4x4saph's Avatar
phil4x4saph
Got a similar prob. on my saph. can I ask a real :blonde: question.
Which bit is the actuator?
Old Sep 17, 2004 | 05:28 PM
Skiman's Avatar
Skiman
i know what bit it is but i dunno how to turn it down lol/....
Old Sep 17, 2004 | 05:29 PM
Billabong's Avatar
Billabong
The actuator is the (usually) bronze/silver coloured thingymabob attached to the turbo compressor housing, with a rod that goes to the exhaust wastegate. Don't recommend playing with it though if you have to ask what it is
Old Sep 17, 2004 | 05:30 PM
Skiman's Avatar
Skiman
if i leave it into the ford rs garage near me it will cost an arm and a leg to fix.
Old Sep 17, 2004 | 05:32 PM
Skiman's Avatar
Skiman
i think i might see a problem,ill try and take a pic now.
Old Sep 17, 2004 | 05:34 PM
Billabong's Avatar
Billabong
Skiman, it might not be overboost cut, are there no reputable tuners near you who could diagnose?
To adjust the actuator you really need to remove the heatshield, and then ideally you need to unclip the actuators arm from the wastgate (otherwise you could possibly damage the diaphragm in the caspule if you just slacken the nut, and twist the rod), then adjust, refit, test etc. but again, you really want to be doing this with an accurate psi boost gauge. As you can imagine, it gets real hot in there if you need to re-adjust!
Skiman - check all the small bore boost pipes are still attached......
Old Sep 17, 2004 | 05:38 PM
Skiman's Avatar
Skiman
anyone on msn that can help me? ive a pic to show u and photobucket is offline.
Billabong's Avatar
Billabong
email it to me at bill@..............com, and I'll post it up.
Old Sep 17, 2004 | 05:39 PM
phil4x4saph
[quote="Billabong"] Don't recommend playing with it though if you have to ask what it is
Good point - Well made!
Old Sep 17, 2004 | 05:42 PM
Skiman's Avatar
Skiman
email sent.thanks
Old Sep 17, 2004 | 05:44 PM
Skiman's Avatar
Skiman
The pic :-
Shows that the coolant hose where it attaches to the turbo,it seems to be leaking due to a very tight jubilee clip which has cut into the hose, would this affect it?
Old Sep 17, 2004 | 05:45 PM
Stu @ M Developments's Avatar
PassionFords Creator
Amal valve may have blown apart of the pipes split... relatively common.
Old Sep 17, 2004 | 05:46 PM
Skiman's Avatar
Skiman
so get a new pipe? would this cause the engine to stall on full boost?
Old Sep 17, 2004 | 05:48 PM
Billabong's Avatar
Billabong
Was just about to say that's not a boost pipe! Ah, you have a small turbo EsCos too .
Old Sep 17, 2004 | 05:52 PM
Skiman's Avatar
Skiman
cheers for hosting that dude...u can see the circular bit of the pipe should not be there and if i move the pipe at all,coolant leaks onto the turbo....could this be the problem?
ahh yes a small turbo...
Old Sep 17, 2004 | 05:54 PM
Are you CERTAIN its not chipped?
Have you actually LOOKED?
Old Sep 17, 2004 | 05:57 PM
Skiman's Avatar
Skiman
i havnt looked...but i was sold the car by one of the heads of the rs owners club n.ire and he said its not chipped...it doesnt seem that quick to be chipped...
Old Sep 17, 2004 | 06:05 PM
Skiman's Avatar
Skiman
just been out, started the car and checked this wee pipe and its definatly leaking coolant onto the turbo...could this be the cause of the stalling?
Old Sep 17, 2004 | 11:14 PM
rsturboo's Avatar
rsturboo
maybe ragging it against a rs turbo could be the problem?
Old Sep 18, 2004 | 12:47 AM
Skiman's Avatar
Skiman
If you've no valid input to this big hole dont reply
Old Sep 18, 2004 | 09:45 AM
Daveyraveygravy's Avatar
Daveyraveygravy
No i doubt it mate, but i would get it sorted coz it's not good to have water dripping onto the turbo!
Try to strip the pipe back hopefully it will be long enough to be able to cut a bit off
Dave
Old Sep 18, 2004 | 09:54 AM
jon foz's Avatar
jon foz
you might want to check that the turbo hasnt failed,if there is too much play in the shaft this could cause the compressor to stall hence restricted airflow,maybe cause it to stall
jon
Old Sep 18, 2004 | 09:59 AM
Lee R's Avatar
Lee R
you'd be a brave man taking an RS to a Ford garage
