Stack Sensors
Old Apr 28, 2007 | 09:23 AM
Ryan's Avatar
Ryan
Default Stack Sensors
Are there alternative for the pressure and temp sensors?
I.e rather than paying 40-50 a sensor from stack?
Ryan
Old Apr 28, 2007 | 09:35 AM
GARETH T's Avatar
GARETH T
sorry ryan i was having major problems last night,,, like i said,, ill see what i can dig on monday
Ryan's Avatar
Ryan
Old Apr 29, 2007 | 09:18 AM
Jasesapphy's Avatar
Jasesapphy
BTTT as i want an answer also
Jasesapphy's Avatar
Jasesapphy
Must be something in the RS Components type cataloge that would do it
Old Apr 29, 2007 | 09:21 AM
Ginge !'s Avatar
Ginge !
just finding my feet
you could steal them
Old Apr 30, 2007 | 09:33 AM
Ryan's Avatar
Ryan
Old Apr 30, 2007 | 09:41 AM
JonnyBravo's Avatar
JonnyBravo
I ran the original GM sensors on my nova with my Stack dash mate.
No problems with anything except for the speedo which was always a bit iffy.
Old Apr 30, 2007 | 10:16 AM
Ryan's Avatar
Ryan
i have some readings of the pressure and temp sensor
Pressure:
VDO 32/14 103
Temp
ST762* 150 ºC Fluid Temp. Sensor (M10)
Old Apr 30, 2007 | 10:19 AM
Ryan's Avatar
Ryan
or is there a solid state alternative?
Old Apr 30, 2007 | 10:22 AM
JonnyBravo's Avatar
JonnyBravo
The guages from my mk2 which my Stack was originally installed in were all VDO senders.
I only know that as I found them in a box the other night
Old Apr 30, 2007 | 10:25 AM
Rippers's Avatar
Rippers
Monte Geek
New VDO sensors are around £50 aswell
Old Apr 30, 2007 | 10:28 AM
RichardPON's Avatar
RichardPON
Hang on...........
Originally Posted by GARETH T a million years ago
I can get you a replacement wheel speed sensor for a fraction of the cost of the Stack item
Old Apr 30, 2007 | 10:35 AM
Ryan's Avatar
Ryan
right according to VDO's site.
The pressure sensor needed is:
0-150 PSI 1/8-27 NPT 32/14 Part No: 360 430
Old Apr 30, 2007 | 10:40 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
You can't use the solid state sensors unless you change your Stack loom as well, as these run three wires....
Old Apr 30, 2007 | 10:43 AM
Ryan's Avatar
Ryan
just seen that mike also according to there site.
¨These digital sensors fit Stack ST8600 or ST700 displays.¨
Old Apr 30, 2007 | 10:54 AM
Jasesapphy's Avatar
Jasesapphy
MIKE
What do you charge for pressure and fluid temp sensors
Old Apr 30, 2007 | 11:59 AM
Mike Rainbird
Caraholic
Fluid pressure 0-150psi (M10 or 1/8" BSPT) = £62.40
Fluid pressure 0-150psi (1/8" NPTF) = £58.16
Fluid temperature 0-150°C (1/8" BSPT, M14, M10 or 1/8" NPTF) = £28.55
All plus carriage.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Mc5506
Sep 29, 2015 09:06 AM
