Spark plug gap!!!
stu i also would like to now as if i use standard plug size on my erst running 15/17 psi it just cuts out on as soon as it boosts? but set at 30 thou on 701c it boosts perfect?
ta
andy
ta
andy
PassionFords Creator
30thou is near as dammit 0.75mm Andy
Std is about 0.8mm i think and thats just slightly too much
Rich,
Only cylinder peak pressures are relevant as one ported head will flow more air at 17psi than a std non ported head as a very very simple example.
Rich,
deathrider666
Sep 28, 2015 06:12 PM
