lambda sensor position
Old Apr 27, 2007 | 06:40 PM
cossie0_4's Avatar
cossie0_4
Default lambda sensor position
i have had a lambda sensor boss fitted to my downpipe it is roughly located on the downpipe just before it goes under the car will this still work a afr gauge ok or is it in wrong possition any help appreciated thanks
Old Apr 28, 2007 | 06:30 AM
Position only important in so much as it needs to be in the exhaust!!
It will still work AFR guage, lamda 1 is 14.66 by the way, but normally reffered to as 14.7 as this is close enough.
Old Apr 28, 2007 | 10:45 AM
cossie0_4's Avatar
cossie0_4
thanks for help cheers
Old Apr 28, 2007 | 02:07 PM
NO probs, hope you get it sorted.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
