i need a chipped ecu NOW !!!!!!!!!!
the tuner has just rung me to say mines fooked .so i need a chipped ecu asap .
anyone got one ???
im at woodzrs@yahoo.co.uk or on 07796072993 kris !
cheers peeps
anyone got one ???
cheers peeps
its got a blue red and black in it , but the garage said either will do ?? ive giving them an old standard ecu i had under my bed . they are checking it 2moro but if its no good i will be pm'ing people !!
cheers peeps !!
cheers peeps !!
cheers peeps !!
cheers peeps !!
Any will do?
Whose your tuner mate?
i know i know , hearts and diamonds are for 90 spec . i will tell you who the tuner when i get the car back . dont want any one writing bad about them , when they have my car
right the one i had is no good . fooked just like the one in the car . right ive got money waiting . now what ive been told to ask is for the seller to remove the cover , then remove the board itself and then whee the boost pipe goes into the ecu , the is some black rubber that is under the board which you can pull to one side to reveal a little round thing with clear gel in it ?? i need one that still has clear gel in it not one that is speckled like the 2 i have .
no ive asked 3 people for pics of this clear gel thinghy and they all said id been told rubbish and that it is a sealed unit ???
so i thought the easist way to see whats what is to look myself . so i did . took 5 mins to take cover off,board off and then move the rubber cover where the boost pipe inlet is and hey presto , there is a little circle thing wwith what looks like clear gel , but with black speckles in it . so if any one can send me a pic of their ecu with this part showing so i can see its clear then the moneys yours. just dont want another that wont work properly . mine will only boost to 10psi and then pimks like fook and they say they have eliminated everything else and when he took the ecu apart he saw the problem .
ive got the money waiting peeps
Just stumbled accross this post!
I had exactly the same problem with my ECU a lot of people dont seem to know about the transducer's failing, the ECU adjusts the timing depending on what pressure is beeing registered by it.
Hence why you were pinking!
yeah the timings been done and done again . the knock sensor was played with at the weekend at they said it was ok . its killing me cos they just dont know what to do next. im changeing the metering unit this week and probably the fuel pump to see if this cures the "lack of fuel " at 10 psi .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
