plenum spacer?
Old Apr 27, 2007 | 11:09 AM
tracktoy's Avatar
tracktoy
Default plenum spacer?
when i picked my engine up last year i got a later escos plenum and spacer at the same time
im going to fit the plenum but is there any advantage to me fitting the spacer
running a 34 with greys
Old Apr 27, 2007 | 11:17 AM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...not really as you are gonna max out at 400bhp anyway...and even the 2wd plenum will see 420 ish bhp before any restriction.
Old Apr 27, 2007 | 11:19 AM
tracktoy's Avatar
tracktoy
now thats what i call a sales man-
sell me a part then tell's me i dont need it
Old Apr 27, 2007 | 12:12 PM
tracktoy's Avatar
tracktoy
although the 2wd plenum will 'max out' at 420, would there be any advantage to having more capacity?
same as with injectors running at 100% not being as good as a bigger injector running at 75%?
Old Apr 27, 2007 | 01:28 PM
Deleted by Request
Former Sponsor
Forgot i sold you that
...yes it will give an extra 45bhp
Old Apr 27, 2007 | 02:43 PM
GARETH T's Avatar
GARETH T
im sure jay cos had to trim more fuel into his fuel map when he fitted his
Old Apr 27, 2007 | 04:31 PM
I have one but to date have not seen any EVIDENCE that they do anything, and was having this very discussion about my one with someone very knowledgeable, who said it was his opinion it was another gimmick, and would do nothing to very little, or a turbo car such as cossie.
I ammin two minds wether to us it or not.
Would be interesting to hear and see any before + after printouts though.
Old Apr 27, 2007 | 04:59 PM
Jay,'s Avatar
Jay,
Sponsor
my afr was set to 11.8 from 18 psi to 32 psi without the spacer . with spacer it was 12.6 afr so i dialed more fuel in so there was a difference to airflow through the manifold
Old Apr 27, 2007 | 05:05 PM
Jay,'s Avatar
Jay,
Sponsor
so in theory more air more power but unfortunatly wasnt tested before and after on the roller's
Old Apr 27, 2007 | 06:04 PM
Thanks that is very interesting as it obviously allowed more air flow, did you notice any other difference ie lower down the revs more torque ?
Old Apr 27, 2007 | 06:08 PM
Jay,'s Avatar
Jay,
Sponsor
yes it did pull better to a tad more lively lower down but that is just the arse dyno should have really done it properly before and after on the rollers
Old Apr 27, 2007 | 08:14 PM
tracktoy's Avatar
tracktoy
so if i do fit it then - its gonna need a remap ?
Old Apr 27, 2007 | 09:02 PM
Jay,'s Avatar
Jay,
Sponsor
possibly it will need checking thats for sure
Old Apr 27, 2007 | 09:05 PM
tregmatt's Avatar
tregmatt
get it fitted paul u..
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
