still no life
Old Apr 26, 2007 | 07:58 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default still no life
right i still cant get fuel out of my injectors i was told to run the pump constantly and open the flap all i got was a whinning sound and the sound of the fuel pump changed i couldnt tell what sort of sound because of the noise from the injectors anyone any ideas what to do next
Old Apr 26, 2007 | 08:06 PM
Alex_86's Avatar
Alex_86
have u tested that u are getting fuel to the fuel filter?
run the pump constantly and take of the fuel lines off the filter
second... u have fuel right?
Old Apr 26, 2007 | 08:28 PM
djmillsy's Avatar
djmillsy
Fife Radge
yeah im getting fuel to the metering head but thats as far aas its getting
Old Apr 26, 2007 | 08:57 PM
Alex_86's Avatar
Alex_86
u have all the connections onnected...
fuel ecu is connected... do u have a extra/spear fuel ecu? if so. try that
Old Apr 26, 2007 | 09:01 PM
djmillsy's Avatar
djmillsy
Fife Radge
yeah ive got another fuel ecu will try it tomorrow whats the easiest way to get into the fuel comp
Old Apr 26, 2007 | 09:51 PM
SafeChav's Avatar
SafeChav
If you're getting noise from the injectors surely they are spraying then
Unlikely to be the fuel ECU as KE operates in limp home mode should something fail.
Old Apr 27, 2007 | 09:55 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Yea as safechav sais, suerly their is fuel coming from injectors if they are making noise (like a horrible squeeling noise?)
did u have the injectors out the inlet to see if they were spraying fuel?
You said in your last post it starts and sounds like a scooby - i'd look at ignition side of things...
also, you say if u take oil cap off it smells of petrol...well sais to me its geting petrol but its not getting burnt!
Take plugs out, get someone to turn it over an check for a spark, give them a wire brush an stick em back in.
Jun 26, 2017 06:18 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
