2wd cosworth
2wd cosworth
Wanted the following
Plastic pipe with the banjo ends that goes between the fuel pump and the filter.
Clear wing repeaters.
Boot hinge covers the plastic items that cover the cables and the hinges
Prop bolts and spacer blocks that are used to bolt the centre doughnut to the chassis
PM or ring 07815879956
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
