Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Unusual 16i Part needed urgently.
Old Sep 18, 2003 | 09:13 PM
LeeBuckman's Avatar
LeeBuckman
Default Unusual 16i Part needed urgently.
Hello All.
I am after the black plastic moulded fuel pipe that goes from the fuel accumulator to the fuel pump for an A reg 16i. Not sure if set up is different from the Y Reg 16i's. Mine has broke and i can't find one anywhere.
Please Help !!!!!
Many Thanks
Lee@Buckman.freeserve.co.uk
Old Sep 18, 2003 | 09:18 PM
Clare's Avatar
Clare
If its the same as the one on a Mk3 Cabriolet (which it probably is) then its unlikely you'll get one cos I spent 7 months looking for one on my old cabby after I broke the steam seals on either end.
Is it the part im thinking of, thin black hose with whats called a banjo fixing on one end and a nut on the other?
If so, take your old banjo and nut to a rubber fabrication company and get them to steam seal them on either end of a piece of hose.
I actually managed to find this part from new (altho was told it was last one in country) but the nut was not the same size as what I needed so made it useless.
If its not the part I described then completely ignore what ive written! lol
155lee
14
Aug 22, 2015 12:15 PM
muz
Aug 16, 2015 12:57 PM
155lee
Aug 14, 2015 11:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
