throttle position sensor
Old Apr 22, 2007 | 10:38 PM
jono9974's Avatar
jono9974
Default throttle position sensor
hi. can anybody tell me if there's a difference between a red tps and a black tps apart from the colour. thanks jono
Old Apr 22, 2007 | 11:46 PM
SafeChav's Avatar
SafeChav
The colour?
On what a RST?
Old Apr 23, 2007 | 06:00 AM
Most likely diff colour as diff make ?
Old Apr 23, 2007 | 10:33 AM
costina's Avatar
costina
Live long and prosper!!
Red TPS = 2WD PF01
Black TPS = 4WD PF09
BUT PF01 (2WD) CAN ALSO BE BLACK!!!!!!
They are different in the way they work but i am not sure the technical side
Maybe someone else can explain for ya and me
Old Apr 23, 2007 | 01:28 PM
jon@work's Avatar
jon@work
Originally Posted by costina
Red TPS = 2WD PF01
and a PF09 can also be red
Old Apr 23, 2007 | 02:52 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The PF01 and PF09 swing the voltage for the TPS reading in opposite directions to each other ie, one goes from 0v to 5v, the other goes from 5v to 0v
Old Apr 23, 2007 | 04:20 PM
Due to a cock up at weber marelli no doubt!!
Old Apr 23, 2007 | 06:22 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I think it was one of those 'fag packet' or 'dinner table' plans
Old Apr 23, 2007 | 09:02 PM
jono9974's Avatar
jono9974
its my 4wd cossie. it has a red tps on it but just got another throttle body with a black tps(pf09) on it. just wondered if it made a difference if i just put it straight on?
Old Apr 23, 2007 | 09:49 PM
cozmeister's Avatar
cozmeister
More boost Igor!
It'll say on the TPS what it is, whether it's a PF01 or PF09.
As long as that numbers the same, it'll run fine
If it's not the same, you'll need to swap them over, as the two are wired differently and work differently. 4x4 Cossies have PF09s because they have L8 ECUs - so check the number and you'll be sorted
Old Apr 23, 2007 | 09:55 PM
jono9974's Avatar
jono9974
cheers mate. by the way the new throttle body has a brown act sensor tapped into it. do you know how they are wired up?
Old Apr 23, 2007 | 10:00 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I bet you won that on ebay I think I was watching it
If it is the same one, the previous owner stuffed it in there for antilag control or something...
Old Apr 23, 2007 | 10:05 PM
jono9974's Avatar
jono9974
this ones off a group a rally escort. didn't win it tho got second chance cos he had 2. but yes its off ebay. it doesn't look any different to the one i've got on except there's a hole drilled in the butterfly and the tps is a different colour.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
