Cosworth L8 ECU, 4x4 Gearbox, Scorpion + More *PICS ADDED*
Team HOTHOT!
A few Cosworth goodies for sale as I'm abandoning my project due to work and time constraints
Green top L8 ECU, Totally standard with original babyboard and original chip. When I bought it, it still had all the screw stickers sealed. I tested the ECU in Slowpokes car and it is perfect. I then took the lids off to check the circuitry for any damage and there is none at all. The idle circuit diode has not burnt out neither. Ideal starting point for an L8 upgrade for your Cossie.
.JPG)
£280 posted by Royal Mail Special Delivery (Insured)
Escort Cosworth turbo heat sheild, in excellent condition, a small part missing at the back bottom where it has been in contact with the exhaust at some point in its life, it has also been lined with aluminium tape on the hot side to protect it, and a brace has been fitted to allow it to be mounted on a strutbrace with ease.
.JPG)
.JPG)
.JPG)
£65 posted by Royal Mail Special Delivery (Insured) Kev KSA Cossie
Coilpack for wasted spark conversion (just the coilpack), used but in excellent condition with no breakdown of the coils
.JPG)
£18 posted by Royal Mail Special Delivery (Insured)
2wd Scorpion Stainless Steel Exhaust. Excellent condition with 4" outward rolled exit. The restrictive middle box has been removed and the entire exhaust has been heatwrapped with that heat cloth stuff. The backbox has a hammer mark where it was separated from the rest of the system. The flange is in excellent condition where it bolts to the turbocharger. The exhaust came off a 3 Door Cossie with a 4x4 exhaust manifold fitted and a T34. Should fit a 2wd Sapph no problems.
.JPG)
.JPG)
.JPG)
£150 ono - Buyer to collect due to size and weight
4x4 Fuel Injection rail + Fuel Pressue Regulator. Good condition, pressure regulator was known good when fitted to the car. The rail is tarnished a bit, but nothing that a quick rub with some 800 wet+dry wouldn't cure.
.JPG)
£35 posted by Royal Mail Special Delivery
I will provide pictures when I get home on Sunday evening and update this thread accordingly.
I accept Paypal or direct bank transfer as payment, or good old fashioned cash on collection.
Postage is included in all the prices except for the gearbox and exhaust, which, for obvious reasons, are collection only.
Anyone requiring anymore details please do not hesitate to contact me via PM. I may be open to negotiation on the price of some of the items - ask and you will find out
Graceland
with regards to the oil take ioof plate
how does it mount?
as i have a oil temp and prssure gauge but i put my sender in the sump plug and a t piece inbetween the block and my oil pressure swithc is very close to the oil filter i had to file the thread down and fit a ring terminal!
would this fit on the remote hosuing of a 4wd and then blt to that then the filter goes onto the plate
how does it mount?
Team HOTHOT!
xr4x4rs - mounting is easy
remove filter, offer up sanwich plate, screw bolt in. It needs a small mod to make it fit a 4x4 remote filter arm, this involves shortening the thread on the remote filter arm so the sandwich plate bolt can tighten the plate down without getting to the bottom of the threads (very obvious once you see it on) and takes about 10 mins to do
Team HOTHOT!
ECU, Gearbox, Loomplugs and Heatsheild are now on ebay
Linky
http://search.ebay.co.uk/_W0QQsassZpaulsimon8QQhtZ-1
Linky
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
