does the frst need the speed sensor connected to !!!
Old Apr 20, 2007 | 07:59 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default does the frst need the speed sensor connected to !!!
to start the car,,, as in a mate of mine has swoped boxes and hes not moved over the speed sensor from the box,,, wondering if the car will start or not ?
Old Apr 20, 2007 | 08:03 PM
rauri's Avatar
rauri
up in smoke........
turn the key and find out?
Old Apr 20, 2007 | 08:04 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yes i believe it will need it to start the car, it needs to know the position of the crank to make it spark at the correct time i'd have thought
Old Apr 20, 2007 | 08:05 PM
crazycage's Avatar
crazycage
Default Re: does the frst need the speed sensor connected to !!!
yes but the speedo wont work
Old Apr 20, 2007 | 08:06 PM
crazycage's Avatar
crazycage
if you meen the crank sensor then no it defo wont start
Old Apr 20, 2007 | 08:11 PM
Ginge !'s Avatar
Ginge !
i said speed sensor not the cps,, i aint that thick
the car AINT starting hence the question
just wondering but if its just for the clocks then he wont bother
Old Apr 20, 2007 | 08:12 PM
MOONDUST FRST's Avatar
MOONDUST FRST
Dont think hes on about the crank sensor, The speedo will work that is done mechanically and the speed sensor is on a leccy multi plug thing.
Mine ran without it connected and Tony from Turbosystems at the time told me not to run it not sure why though
bud-weis's Avatar
bud-weis
Football Cwazy
CPS is somtimes called the speed sensor
and clearly you ARE that thick if you thought it wouldn't start cos the speedo signal ain't connected
Old Apr 20, 2007 | 08:15 PM
focusv8's Avatar
focusv8
Speed sensor, ( VSS) as in detecting when the car is moving.
No explanation neccessary.
Old Apr 20, 2007 | 08:16 PM
Ginge !'s Avatar
Ginge !
maybe cause SOME ecu's wont start unless all sensors are conected when they turn the key as they self test and find a broken circuit so wont allow to start as a saftey measure,,, but you wouldnt know that cause your still using a car with 1970's engine management
Old Apr 20, 2007 | 08:18 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i'm running T6 now
not
Ginge !'s Avatar
Ginge !
btw ive had peopla at work call stuff all sorts,,, but dont mean its the actual name people refer to when you want a REAL answer
but then thats cause the cam sensor is to mesure the engines speed,, the crank sensor is for the bottoms end position based on the crank spins twice as fast as the the real engine speed
Old Apr 20, 2007 | 08:20 PM
Ginge !'s Avatar
Ginge !
Originally Posted by bud-weis
i'm running T6 now
not
bit pointless if you was tbh,,, considering the car works and you dont require all the extra functions the T6 offers
but then ive turned into a lateral thinking person
Old Apr 21, 2007 | 08:14 AM
Rolls's Avatar
Rolls
Ginge, it will start fine mate - mine did in the xr2
Old Apr 21, 2007 | 08:54 AM
cos jon's Avatar
cos jon
Yeah it will run fine without it, i took mine out as the internal drive broke, just put the speedo cable in its place.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
