Help with how to use engine stand
Old Apr 20, 2007 | 07:36 PM
banditbarron's Avatar
banditbarron
Default Help with how to use engine stand
Can you guys please help me as i have now bought an engine stand and am picking my 2.0 up 2moro, Any advice on how i mount the zetec block on the stand? Pix would be great if possible, cheers Dave.
Old Apr 20, 2007 | 08:45 PM
You don't need pics.
Just get the bolts for the stand "holder" bit, adjust holder so that the holder goe onto the four points on engine block doesn't matter wich so long as al four legs are adjusted so they go on the block.
Bolt it up to the block, then stand block on end that is not bolted(front) and place the other part of stand(feet bit) onto the holder bit, then lift upright, easy.
Old Apr 21, 2007 | 11:27 AM
JesseT's Avatar
JesseT
Not a Zetec, but a CVH, but it's the same bottom end more or less anyhow:
http://www.kolumbus.fi/ulpu.tuominen...at/efikone.jpg
http://www.kolumbus.fi/ulpu.tuominen/JT_kuvat/naku.jpg
Billy_RS
16
Oct 11, 2025 09:41 PM
Sheepdisease
Aug 30, 2015 09:11 PM
TrevCos
Aug 22, 2015 06:05 PM
IAN RS2k
Aug 18, 2015 07:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
