INSTALL MSD CLOSED LOOP CHIP,please help!
Old Apr 20, 2007 | 12:59 PM
Thanasis's Avatar
Thanasis
Default INSTALL MSD CLOSED LOOP CHIP,please help!
hi,i install the msd chip,lambda sensor,TPS(PF09) in 2wd car and wiring loom(L6),now i have L8 ecu,all perfect expect the idle speed valve,when i connect the idle valve plug then the rpm's is under 4000rpm maybe more,what's happen?
do you know anybody?
thanks a lot.
Old Apr 22, 2007 | 11:56 AM
opposite lock's Avatar
opposite lock
your question isnt as clear as it could be , do u mean the engine wont rev past 4000rpm ? also if your loo m is level 6 ,does it mate up too a l8 tps ?
Old Apr 22, 2007 | 04:37 PM
trevCOSS's Avatar
trevCOSS
have you swapped the wiring on the loom? Top and bottom wires on tps plug must be swapped when going from l6 to l8, as above question isnt 100% clear
tankybaby66
Feb 6, 2016 02:24 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
