SPARK PLUGS AND GAPS ??????? FOR COSWORTH
Apr 20, 2007 | 12:08 AM
just wondering if you have to gap a spark plug before you fit them to your cossie i thought when they are new you could fit them straight in just out the box and straight in is this true
by the way the ones im on about are the genuine ford ones AGPS071C if you have to gap them then what are the measurements ??
thanks
tony
Apr 20, 2007 | 06:38 AM
I gap mine to 0.6mm on my stg3 saff mate
Apr 20, 2007 | 06:57 AM
Good luck, they're devils to do
Apr 20, 2007 | 07:00 AM
0.6mm for me too, but AGPR12PP8 work way better.
Get also a group a coil, you will think it is the best Ł32 you ever spent!!
Apr 20, 2007 | 08:36 AM
Quote:
Same here.
Apr 20, 2007 | 09:10 AM
me too.
Apr 20, 2007 | 09:30 AM
Apr 20, 2007 | 09:33 AM
ooooo, seeing you reminds me... Must phone grove!
the biggest you can get away with without a miss-fire
Apr 20, 2007 | 10:28 AM
but do you have to gap them ?? what do they come as out the box?? ive got a grp a coil too
havent got the tool to measure the gaps
Apr 20, 2007 | 10:34 AM
you only need feeler gauges,,, i always check the gapping of my plugs from new
Apr 20, 2007 | 04:03 PM
Apr 20, 2007 | 04:08 PM
gap mine to 20 thou as recommended by Harvey Gibbs.
Apr 20, 2007 | 04:09 PM
also dont forget when gapping them you need to have the feeler gauge at an angle
Apr 20, 2007 | 06:57 PM
Apr 20, 2007 | 07:03 PM
Quote:
What is that in mm?
0,6 or?
Apr 20, 2007 | 07:13 PM
30 thou on mine coil pack RS500 as told MARK AT GROVE !!
Apr 20, 2007 | 09:28 PM
0.1 mm is 4 thou, 0.6 is 24 thou.
25.4mm to inch
40 thou to 1 mm
10 AWG is 3MM
12AWG IS 2.5MM
14 AWG IS 2.0MM
16 AWG IS 1.5MM
18 AWG IS 1.2MM
20 AWG IS 0.9MM.
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Zoggon
Aug 10, 2015 10:39 AM
adriansaleem
Aug 1, 2015 09:28 PM
