3 door rev counter
Old Apr 19, 2007 | 05:01 PM
jason 3dr's Avatar
jason 3dr
Default 3 door rev counter
a any one used this conversion to drive there rev counter on wasted spark
Old Apr 19, 2007 | 05:41 PM
jon@work's Avatar
jon@work
yes - but with a 5K resistor added as shown below :
Old Apr 20, 2007 | 04:30 PM
jason 3dr's Avatar
jason 3dr
whats the reason for this
Old Apr 20, 2007 | 04:39 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Jason is there a reason for mahhhhhhhhooooooooooooosive gap between your sig pics
hello btw!
Old Apr 20, 2007 | 05:05 PM
jason 3dr's Avatar
jason 3dr
what
gap
Old Apr 20, 2007 | 05:06 PM
jason 3dr's Avatar
jason 3dr
Old Apr 20, 2007 | 05:39 PM
jon@work's Avatar
jon@work
it wouldn't work without it - try it your way then mine if necessary
Old Apr 20, 2007 | 05:55 PM
jason 3dr's Avatar
jason 3dr
thanks. are you using it
Old Apr 20, 2007 | 05:57 PM
jason 3dr's Avatar
jason 3dr
just trying to get my 3dr rev counter working as there is no conversion for them unlike the saphs
Old Apr 20, 2007 | 06:20 PM
jon@work's Avatar
jon@work
Nope, I don't need it - I haven't got a 3dr. But it makes a friend's cossied capri rev counter work with wasted spark, so for the cost of the bits, give it a go.
Old Apr 20, 2007 | 06:45 PM
jason 3dr's Avatar
jason 3dr
cheers i will it was only 26p
Old May 10, 2007 | 08:44 PM
2wd's Avatar
2wd
Hi, I'm not quite sure how to wire this this up ....
I run a 2wd Sapp, and have just changed to wasted spark, and the rev counter is not correct now. I cant use the rev counter/tacho. instruction witch followed the kit as my rev counter is different......
so please....HEEELP...
Old May 10, 2007 | 09:44 PM
Stu @ M Developments's Avatar
PassionFords Creator
See here pal.
https://passionford.com/forum/viewto...868188#3868188
155lee
Oct 24, 2015 11:11 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
Vincereese
Sep 18, 2015 12:47 PM
Mark V8
Sep 13, 2015 09:34 AM
