EBC brakes
Old Apr 19, 2007 | 10:19 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Default EBC brakes
I've ordered some brand spanking new EBC front discs and pads for my Saff.
I know the 3 door and 2wd Saff have the same calipers, but I don't remember the Saff having any kind of brake wear indicator (apart from not stopping )
The pads I've received are for 2wd 4 pots, but have the cable for the wear indicator - am I ok to just tie this up somewhere or lop it off?
Old Apr 19, 2007 | 11:30 AM
Ridgey's Avatar
Ridgey
cut it off.
Old Apr 19, 2007 | 11:58 AM
Cut it off.
Old Apr 19, 2007 | 12:06 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Looks like I'll be cutting it off then!
Old Apr 19, 2007 | 12:12 PM
It is possible to utilise the wear indicators if you wish as they are only two copper pads in the pad to complete a circuit when pressed against the disc and worn down enough, disc complete the lecky circuit.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
