mk4 escort central locking wiring!!!!!
Morning peeps. Going to fit another alarm to the escort but having bit or trouble finding the central locking wires to wire into the alarm. Anyone know which ones??
You just need to find out the wire by probing with a test light as you will see a quick flash, or long flash depending on time signal, for lock unlock.
Find the one that goes pos on lock and the one that goes pos on unlock then follow alarm directions easy.
Would be best to do this to check so might as well just do this to start with!!
