Any technical people!!!? Help!!
Old Sep 16, 2004 | 01:29 PM
K3V HA's Avatar
K3V HA
Default Any technical people!!!? Help!!
Please please could you have az look at this in the technical section!!
https://passionford.com/forum/viewtopic.php?t=73397
Old Sep 16, 2004 | 01:39 PM
K3V HA's Avatar
K3V HA
Cmon, anyone??
Old Sep 16, 2004 | 01:55 PM
foreigneRS's Avatar
foreigneRS
Testing the future
broken wastegate/actuator?
Old Sep 16, 2004 | 01:56 PM
Jim Galbally's Avatar
Jim Galbally
you mean there are more furums that general discusion?
Old Sep 16, 2004 | 02:33 PM
DOO's Avatar
DOO
actuator as come loose 100%
Old Sep 16, 2004 | 02:34 PM
Jim Galbally
by that i assume you mean you never put thr actuator rod on properly doo?
Old Sep 16, 2004 | 02:54 PM
DOO's Avatar
DOO
not the rod end the actuator end .stupid size fooking nuts could never find the correct ones
came loose a few times in the past
Old Sep 16, 2004 | 02:58 PM
K3V HA's Avatar
K3V HA
Still cant find what to tighten!! Will it be alright to drive though??
Old Sep 16, 2004 | 03:01 PM
DOO's Avatar
DOO
Where the acuator fits onto the turbo 2 nuts about 10mm spanner size
Old Sep 16, 2004 | 03:05 PM
K3V HA's Avatar
K3V HA
Right, i see em, but there not loose!! It is loose a little bit, but not from there, the bracket that attachs it to the turbo is loose, about a 13mm nut? Could that be it??
Old Sep 16, 2004 | 03:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
It could be...
Depends how loose we are talking about though, if its just flexing a little as its pressurised then NO. If the bolts are physically loose, then yes.
Old Sep 16, 2004 | 03:08 PM
DOO's Avatar
DOO
yes mate it would be ok to drive.
yep would be that bracket thing then but it`s a right fooker to get to prob have to take the acuator off to tighting the bracket up
Old Sep 16, 2004 | 03:18 PM
K3V HA's Avatar
K3V HA
Right, ive spotted the 2 bolts that hold the bracket on, they are both loose!! Will get teh car over my pit in me garage tonight and tighten up!!
Thank you Stu, Doo, Jim and foreign RS!!
Old Sep 16, 2004 | 03:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you're welcome mate, that's what makes this forum great. now we've solved the problem for free for you, put the money that you would've spent getting it sorted at a garage into passionford to keep it up and running.
Old Sep 16, 2004 | 03:38 PM
DOO's Avatar
DOO
Right, ive spotted the 2 bolts that hold the bracket on, they are both loose!! Will get the car over my pit in me garage tonight and tighten up!!
Old Sep 16, 2004 | 05:45 PM
K3V HA's Avatar
K3V HA
Just tightened it up and its running proper again!! Wahoo!!
PF does it again with technical help!!
Old Sep 16, 2004 | 06:54 PM
K3V HA's Avatar
K3V HA
Arrrgghh!!! its come loose again, any idea why it would be doing this?? I only tightened it up an hour ago, and its come undone again!!! Please help!!!
Old Sep 16, 2004 | 08:07 PM
Alps Pacino's Avatar
Alps Pacino
you need to use some lube elbow greese always works for me
Old Sep 16, 2004 | 08:24 PM
It's Czech Mate's Avatar
It's Czech Mate
Threadlock?
Old Sep 16, 2004 | 08:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
locking nut!!!?? tighten it up, get 2 nuts the same and tighten them onto the tightened nuts
Old Sep 16, 2004 | 10:49 PM
DOO's Avatar
DOO
I think you better lock tight everything
I had a few things come loose (inc the exhaust fall off at perfomance ford shoot out at burnters
it was on the job to do list but never got round to doing it
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
