Whats the offset on a escort cosworth
Apr 18, 2007 | 10:47 PM
what is it
and would et42 fit???
thanks jamie
Apr 18, 2007 | 10:51 PM
et25 is standard.
don't think they will look too good.
et 42 will sit in wat too much.
Apr 18, 2007 | 10:54 PM
what does the number represent?
Apr 18, 2007 | 10:55 PM
Apr 18, 2007 | 10:59 PM
the smaller the number the more the wheel sticks out.
it is the distance from the hub face that the wheels sticks out......soething like that.
Apr 18, 2007 | 11:01 PM
would that not mean the higher the number the more they stick out then Dave?
Apr 18, 2007 | 11:20 PM
the higher the number the more they go inside behind the nuts/hub face.
the lower the number the more they stick out from the hub face,so they fill the arches better.
if you can understand that.
Apr 18, 2007 | 11:25 PM
imagine a center line along the hub face.....looking at it from the front of the car.....
the higher the et number the more it sits to the left of the center line,the lower the number the more it sits to the right of the center line......yes.
there are pictures on here somewhere.
Apr 18, 2007 | 11:27 PM
I get it
Apr 18, 2007 | 11:28 PM
Apr 18, 2007 | 11:45 PM
*** Sierra RS Custard ***
As Dave says, they would sit too far in, possibly by enough to foul the suspension in fact.
Apr 19, 2007 | 12:21 AM
ET42 is more than likely a Focus wheel
Apr 19, 2007 | 05:50 AM
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel:
Apr 19, 2007 | 08:48 AM
thanks that makes it clear now. so i want an et in the low 20's.
thanks guys
Apr 19, 2007 | 08:52 AM
Et15 looks the best of an Escos. Thats what Martin reccomends and sells his MOs in.
Apr 19, 2007 | 04:40 PM
Quote:
Originally Posted by Alps Pacino
think mine are et22
yours are definately ET25
i paid an arm and a leg to get a matching one as there was one odd wheel on it when i got it( un known to be) and it took fookin ages to sus out why it wouldnt track up properly, only when i took them all off and inspected them with a fine tooth comb i noticed one was a ET20, which im trying to sell at the moment
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
