RS1800 ecu help please
Old Apr 18, 2007 | 08:00 PM
extremexr2's Avatar
extremexr2
Default RS1800 ecu help please
Right a friend of mine has just got a rs 1800 throttle body & cult ecu from a 94reg car which he fitted 2 his xr2i however with the new ecu plugged in the engine wont start fuel pump works but it just turns over i know cult ecu,s can be a pain with compatability but is this just a fooked ecu or has sumthing else got 2 be changed any ideas would be appreciated thanx
Ps everything else is standard 105ps
Old Apr 18, 2007 | 11:10 PM
SafeChav's Avatar
SafeChav
Do they have coded keys?
Old Apr 19, 2007 | 08:04 AM
sailorbob's Avatar
sailorbob
Is the XR2i external EDIS? If so, you cannot do a straight swap without a little bit of re-wiring of the loom because the CULT ecu has internal EDIS.
Old Apr 19, 2007 | 10:24 AM
extremexr2's Avatar
extremexr2
the xr2i is external edis ! so which wires hav 2 be alterd thanx for the help
Old Apr 19, 2007 | 10:29 AM
SafeChav's Avatar
SafeChav
You best get yourself a wiring diagram mate it won't be easy to explain on here
Old Apr 19, 2007 | 10:33 AM
sailorbob's Avatar
sailorbob
See this http://www.fiestaturbo.com/forums/qu...-ecu-vt132683/
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Brian
Sep 11, 2015 08:06 AM
