failed MOT :(
Old Sep 16, 2004 | 12:38 PM
RSCAT's Avatar
RSCAT
Default failed MOT :(
ABS, apparantley its got to be working,
mine has been disconnected but yet went through the mot last
time like that
where is it most likely to be disconnected from?
Old Sep 16, 2004 | 12:41 PM
hooked_on_boost's Avatar
hooked_on_boost
Does the little light come on then go off like it should?
I had problems with my erst when I disconnected the belts on the abs, it went thru but they said they wont do the test again unless I completly remove the system!
Old Sep 16, 2004 | 12:42 PM
Ginge !'s Avatar
Ginge !
just finding my feet
change the mot station mate , or unplug a bulb , wire it up to the oil presure light
Old Sep 16, 2004 | 12:44 PM
SteveT's Avatar
SteveT
I am sure the ABS doesn't have to work, but if your ABS warning light is on (common on RST's with broken/slack belts) then they can count that as a fail. Remove belt, adjust belt or remove warning light.
steve
Old Sep 16, 2004 | 12:47 PM
Ginge !'s Avatar
Ginge !
cossies are different though aint they, not a mecahnical abs
dont think he has it on his car either ???
Old Sep 16, 2004 | 12:52 PM
RSCAT's Avatar
RSCAT
nah, the two little lights stay on all the while
i think with the fact hes already noted it, ill have to get it working. he said all the sensors are still there, so im wondering where its most likely been disconnected ?
no can do mate, ive already lashed at the dough on this one and im too tight
to pay again, esp since thats all it failed on
me too, thats why it went through last year different station like.
Old Sep 16, 2004 | 12:53 PM
RSCAT's Avatar
RSCAT
yeah theres 2 little yellow ones on the middle of the dash.
Old Sep 16, 2004 | 01:02 PM
Ginge !'s Avatar
Ginge !
wire the warning lights on ya dash upto the oil presure light, then when ya get the oil presure the oil and the abs lights turn off
big thanks to steve at scc for the hint
Old Sep 16, 2004 | 01:08 PM
RSCAT's Avatar
RSCAT
oh fook i really dont wanna take the dash out as something wont work when i put it back in, i just know it.
Old Sep 16, 2004 | 01:09 PM
Ginge !'s Avatar
Ginge !
then take it to steve at scc and he will do it
Old Sep 16, 2004 | 01:13 PM
RSCAT's Avatar
RSCAT
trouble is, the mots out now, and coppers round here will jump on me if im going anywhere other than the mot station, in fact a patrol car went round the roundabout twice to follow me down a stretch of road today on the way back from the station. didnt stop me though which makes a change.
Old Sep 16, 2004 | 01:15 PM
Oranoco's Avatar
Oranoco
Pull the belt break sensor out of the modulator and use a zip tie to hold the metal switch closed. Job's a goodun. Only takes 30 seconds and no tools are required.
They do not actually test the operation of the ABS system just that the warning lights do as they should.
Old Sep 16, 2004 | 01:16 PM
Ginge !'s Avatar
Ginge !
take the bulb out of it then
RSCAT's Avatar
RSCAT
but doesnt that mean they wont even come on with the ignition on?
Old Sep 16, 2004 | 01:17 PM
Ginge !'s Avatar
Ginge !
or put a sticker over the bulb so then cant see it
Old Sep 16, 2004 | 01:41 PM
Oranoco's Avatar
Oranoco
The ABS warning system will work as normal mate. It will still illuminate both the Hanbrake and ABS lights when the hanbrake is applied.
All you are doing is fooling the warning circuit into thinking the belts are both there and that everything is fine.
Old Sep 16, 2004 | 01:53 PM
neilm's Avatar
neilm
This sounds like you have a faulty ABS sensor
And they aint cheap.
When you put the ignition on, without starting the engine, can you hear the ABS pump prime ? A buzzing noise that will go on for around 20-30 seconds
Old Sep 16, 2004 | 01:58 PM
Oranoco's Avatar
Oranoco
Just realised chap that you are prob talking about Cossie's and not RST's.
My boob mate. Sorry.
Old Sep 16, 2004 | 02:24 PM
Ginge !'s Avatar
Ginge !
thats what i was saying, just rewire the bulb jpb done
Old Sep 16, 2004 | 04:30 PM
RSCAT's Avatar
RSCAT
ill have to go out and check, i cant remember lol.
in the mag article it said the abs had been disconnected so i assumed
this was a deliberate thing and not due to a fault ?
also all the sensors were checked with a pectal thingy and none were faulty but wether that includes the abs one i dont know, maybe just engine sensors?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
