Cosworth Expert Required... Apply within!!!! ;)
Old Apr 17, 2007 | 07:28 PM
mattajturners's Avatar
mattajturners
Default Cosworth Expert Required... Apply within!!!! ;)
I have a Sapphire 2000E which I am now wanting to convert to a RWD cosworth.
Please can someone make me a list of items/parts that I will need
i.e Ream beam, diff, Wiring loon etc etc
Thanks in advance!
Old Apr 18, 2007 | 05:25 AM
This would fill a whole page on it's own!!
BASIC,
ENGINE, GEARBOX/BELL HOUSING, , DIFF/SHAFTS BRAKES(F&R) WHEELS, ECU + LOOM, INTERIOR, BODYKIT, INTERCOOLER/RAD/PIPES.
There is no doubt masses left out, just find out as you go along!!
Old Apr 18, 2007 | 06:20 PM
Alvyn's Avatar
Alvyn
best bet would be to sell 2000E and buy a 2 w/d Cossie
Old Apr 18, 2007 | 06:49 PM
mattajturners
With my small budget I could only afford a rotted/smokey/jank cossie!!!
I now have a BIG list of parts needed but does anyone know if i need to change:-
Fuel pump
Engine mounts
Rad Fans
Clutch/hande brake/speedo cable/s
Pedals
power steering rack
Thanks again!!
ps
if anyone else needs the list, let me know and i'll send it over!!
Old Apr 18, 2007 | 07:41 PM
trevCOSS's Avatar
trevCOSS
fuel pump yes, also I think the tank may be diferent on the 2000E, rack no, pedals no, mounts probably as I think the arms are different, handbrake no speedo no clutch cable quite possibly, rad fans and rad yes think so
Old Apr 18, 2007 | 08:37 PM
Alvyn's Avatar
Alvyn
speedo will also need to change as cable is different and the speedo head DOESN'T go to 170mph in a 2000E,wiring looms,doing away with master brake cylinder! will add as I remember but there WILL be loads of other things m8.
Old Apr 19, 2007 | 05:55 AM
If you want it to look cossie the speedo as said will need changing, but turn/clock ratio the same so will fit to old 2000e clocks and work accurately.
Old Apr 19, 2007 | 03:49 PM
mattajturners
Please let me know if i've missed anything!!
I have most items, just need the items with *, please contact me if you have any for sale... 07999 077 616...!
items to date
rear axle
rear diff
prop shaft
rear callipers
rear disks/pads *
front beam
front hubs
front callipers
front bottom arms
front disks/pads *
track rod ends
complete wiring loom
ecu
complete engine hose kit *
radiator *
intercooler *
rwd gear box*
gear linkage **
gear stick**
complete engine / turbo etc *
complete exhaust / manifolds *
handbrake/clutch cable **
alternator
starter motor
complete set of water pot / p-steering etc **
fuel pump **
engine mounts **
radiator fans **
** = I need to know if i need the following!!!
thanks again...
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
