bailey oil separators
Old Apr 17, 2007 | 04:29 PM
18"chris's Avatar
18"chris
Default bailey oil separators
im thinking of fitting the above,ive read the catalogue and am unsure about the vent hose.
does this just vent fumes out under the car,obviuously its attached securely but is it that simple?
does any1 have any diagrams or pictures relating to this.
cheers
Old Apr 17, 2007 | 05:53 PM
Daxcossie's Avatar
Daxcossie
Ive got mine vented from both side of the block and oil returning to the sump. The atmosphere pipe is then connected to a Mocal oil catch tank.
Old Apr 17, 2007 | 09:07 PM
18"chris's Avatar
18"chris
cool,does it have to go to a tank as its only a vent or can i tuck it away nicely with a mini breather attached
cheers
any help is much appreciated,no matter how small
Old Apr 18, 2007 | 09:40 AM
rinus_2005's Avatar
rinus_2005
the vent hose can simply be tywrapped to the chassis
Old Apr 18, 2007 | 07:18 PM
Daxcossie's Avatar
Daxcossie
If your going to track your car then I would still connect the breather pipe to a catch tank as the oily vapour can lay on the track and end up all over the underside of your car
http://cgi.ebay.co.uk/ALLOY-BREATHER...QQcmdZViewItem
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
