Frog's 4x4 cossie goes clink clink clink - sorted
Old Apr 16, 2007 | 06:36 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Frog's 4x4 cossie goes clink clink clink - sorted
Been getting worse over the last few days, and I can't put my finger on it...
Sounds like two tablespoons being banged together, fairly high pitch, but distinct clink clink clink noise.
I figure it could be a whole host of things, but I was hoping that maybe I wasn't the first
Here's when it happens:
-It's intermittent.
-Not revs related, doesn't happen at standstill, revving engine makes no difference when the noise is there.
-Was originally only during coasting, following light application of the brakes.
-Now it does happen under mild power (possibly can't hear it on full boost due to induction/wind noise).
-Happens both on smooth and uneven roads.
-Clutch down/up, neutral or in gear - no difference.
-Suspension feels/looks ok.
Here's what I have checked:
-Crawled under the car front and back, can't see any major items missing or loose, same under-bonnet.
-Drove with left, then right, then both windows open, can't tell which side, however it feels like right hand side.
-Exhaust and propshaft are clear.
-Tightened exhaust to turbo housing bolts yesterday (were a little loose), no difference.
-Drive shafts and propshafts aren't moving (no sideways movement).
-Engine mounts look ok.
The only thing I can think of, is that the brake pads are on the 3 to 5 mm thickness, and the brake pedal feels a little spongy. Car brakes fine, but I was thinking that maybe one of the pads is rattling in the caliper due to lack of overall thickness
Any ideas most welcome
Old Apr 16, 2007 | 09:15 PM
Alvyn's Avatar
Alvyn
check the front prop u j as the grease inside goes off due to exhaust heat and the weather!
Old Apr 16, 2007 | 09:18 PM
rapidcossie's Avatar
rapidcossie
Cv joint?
Old Apr 17, 2007 | 06:23 AM
KSA-Cossie's Avatar
KSA-Cossie
Sounds like front prop,would also check rear one too.
Old Apr 17, 2007 | 07:50 AM
frog's Avatar
frog
Thanks guys, I'll have a closer look at the props.
In the mean time, I checked wheel bearings, they are fine, also drove car in circles left and right, didn't make any difference, no noise
If it was the driveshafts, would you not expect some play in them ? They are rock solid when I try to wiggle them
Old Apr 17, 2007 | 05:37 PM
frog's Avatar
frog
Right, thought about it some more and driven the car today.
If it was the driveshaft or propshafts, I expect the frequency of the rattle would decrease as the car slows down, and yet, it doesn't.
Sometimes it's a really fast rattle, it slows down, stops, then starts again, totally out of control.
It actually sounds like a metal plate rattling about
I am thinking it may be the gearbox now... shifting from 3rd to 4th and back to 3rd repeatedly at a standstill, engine off, the noise is sort of there, clink, clink with every shift
Could something have rattled loose in the gearbox causing the noise ?
Old Apr 19, 2007 | 11:13 AM
bud-weis's Avatar
bud-weis
Football Cwazy
what turbo damper do you have fitted??
Old Apr 19, 2007 | 11:44 AM
frog's Avatar
frog
Erm, none I think, it's a 4x4
The turbo damper on our 2wd did loosen up a while ago, and it sort of sounded the same though
Old Apr 19, 2007 | 06:45 PM
S.Hannah's Avatar
S.Hannah
Could be the clutch bearing.
Mine does that.
next time it does it put your foot down on the clutch and see if it dissapears.
Stephen
Old Apr 19, 2007 | 09:48 PM
frog's Avatar
frog
Mine does that.
Stephen
Will try that too thanks
Old May 1, 2007 | 07:28 AM
frog's Avatar
frog
Well, it could any or all of the above, I simply will never know
The noise has gone away now, so either something's fallen off for good, or, it put itself back in place til next time
I did find a loose headlamp clip in the engine bay, lodged between wires below the coil, so maybe that's what it was, but it looks a little too small to make such a noise
Thanks for the help peeps
Old Aug 6, 2007 | 07:01 AM
frog's Avatar
frog
Quick update - Turned out to be the propshaft that goes from transfer box to front diff.
THe knuckle near the front diff (and close to the exhaust) was all dry and rusted and there was loads of play in it.
Now replaced and greased up and is all noisless
Old Aug 6, 2007 | 07:21 AM
KSA-Cossie's Avatar
KSA-Cossie
Nice easy fix eventually.
Old Aug 6, 2007 | 07:41 AM
frog's Avatar
frog
Easy in theory, but I had a nightmare swapping it !
Took it off ok, except that I need to get longer hex bits. Then realised it wasn't coming off without the exhaust out of the way, so needed to buy a proper trolley jack to get the height I needed.
Got the prop off and back on, then the exhaust and only then realised that the exhaust clamp wouldn't make it past the prop, so off with the exhaust again.
Rounded off one of the allen bolts when removing the prop second time, so had to drill and extract it , get a new set of bolts and do it properly all over again !
Oh well, it's on now, and I've got some shiny new tools as a result
Another one of those simple jobs that turned into a bit of a marathon !
Old Aug 6, 2007 | 07:46 AM
KSA-Cossie's Avatar
KSA-Cossie
Result on the tool front then
Old Aug 6, 2007 | 01:28 PM
Its always the same 1 simple job turns into a right nightmare.
Thanasis
Sep 7, 2015 07:33 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
