l8 ecu --- in 2wd
hi all, i would like som advice on fitting an l8 ecu with closed loop .will i need a custom loom or will the 2wd/4x4 loom work with mods, would rlly like some help , cheers
Dont quote me on this 1 but as far as i know, when changin over 2 l8 from l6 it a matter of swappin the throttle position senser over 2 a 4wd 1 and then i think thats it, at the worst case it will b a couple of wires u need 2 change, u dont need a new loom, as 4 the closed loop stus r the man 2 talk 2 bout that
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
DixieTheKid
Sep 14, 2015 09:04 PM
