fittment of baileys oil breather!
Theres 3 bits where pipes go on. At the back of the rocker cover on the cam pulley side at the back there is an oil breather there. One of the pipes goes to this. Another one goes down to the block/sump about 8 - 10 inches under where the breather sits & the last one goes to the air flow meter.
HTH
HTH
You're right on that one 2 do go to the rocker cover. I thought there was another one just couldn't remember it. The fourth does go to the air flow meter but some people do have them just going to the atmos.
as above that is deff right. you can have the 4th one either going to atmosphere or back into the metering head.. if its going to atmopshere make sure you block the one to the metering head back up or it wont start!
does it make a diff to the running of the car if i run the pipe to the airflow meter or block it off?
