3door help
Old Apr 16, 2007 | 02:18 PM
normink's Avatar
normink
Default 3door help
wondering if anyone can help, when driving the car on the odd ocassion when u put your foot down on the accelator im getting a miss fire, once u back off it clears and the power goes down again. Red engine light then comes on in the dash. Thought it might of been the phase sensor so changed it, the dist cap and rotor arm at the same time but the problems still there, any ideas would be great. thanks.
Old Apr 16, 2007 | 07:21 PM
daz1968's Avatar
daz1968
If the red light comes on then short the two wires in the ecu plug and read the codes, should point you in the right direction and you can follow the breakout box checks in the manual.
Old Apr 16, 2007 | 08:13 PM
Harris.'s Avatar
Harris.
Mine did this, the whole car judered for a split sec then the red light came on,i had the crank sensor re gapped
Old Apr 18, 2007 | 05:50 AM
"Had the crank sensor regapped", diy man it is so easy 10 minutes.
As for the misfire might pay to do the wiggle test on the connector for the CPS as one end is still old pins in housing.
Old Apr 18, 2007 | 09:50 PM
normink's Avatar
normink
thanks for ideas folks give it another try over the weekend
Old Apr 19, 2007 | 06:04 AM
Good luck, cossie's don't you just love them!!
pugo
Jan 14, 2006 04:37 PM
chriswrx
Nov 11, 2005 10:08 PM
Gaaables
14
Dec 29, 2004 06:21 PM
CozzyBrom
23
Oct 5, 2004 03:08 AM
CozzyBrom
Jul 14, 2004 06:05 AM
