brake kit, HELP!!!!
I recently bought a goodridge brake line kit for my 2wd sapp, but a kit for a 4x4 arrived. As far as i can see this kit wont match up to my brake as the treads on the lines seem to be too big for the calipers.
The supplier is telling me its the correct kit, that the the 2wd and 4x4 lines are the same, can anyone confirm this for me or do i need a different kit as i suspect i do
Yep mate..fits both! Ive just fitted a Goodridge 4x4 6line kit to my 3dr cossie
The longest line goes to your front calipers and goes from the subframe brake line mounting (as normal) and then goes straight to the caliper (removing the need for the calipers hard metal pipe)...fit the hose to the caliper side first, short thread to caliper then longest thread to mounting on subframe. The rears are quite self explanatary when you come to fit them up.
Stu.
Stu.
