Weber Marelli management **NOW WITH PICS**
Engine Machinist
taken from a Lancia Dedra 2.0 turbo, equivalent to cosworth level 8 (similar age and insides are almost identical). this includes the ecu, loom, injectors, distributor with phase sensor, map sensor, throttle body and sensor, ignition module, iscv and crank sensor, so basically everything that you could need to run your rst on cossie management.
i'm looking for £175 for the lot
The crank sensor pick up is the same as the cossie and so is the cam sensor, i looked into using this but decided to not go turbo. There is a superchip available, which are slightly custom mappable. I would have thought motorsport developments can chip it in the same way as normal cossie ecu`s aswell. Hope this helps.
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
deathrider666
Sep 28, 2015 06:12 PM
