Vacum Line Connections on series 2 rs turbo
Hi I need all your help here.
I am just in the process of fitting a fiesta efi rs turbo cvh engine into my mk4 efi orion. This is my first turbo engine.
Engine is now in and I am now stuck with where all the small vacum lines should go.
I have a outlet on the actuator, one on the garret t3 turbo housing, one on top of the intake manifold, and i need to connect a line from boost gauge which has a tee peice, and also a line from top a boost gauge, but no idea which order the pipes go and where the tee peice goes.
Any help greatley appreciated. Dont want to cock it up.
Paul
Paul
The compressor housing usually connects to the amal valve, then back out of the amal valve to the actuator.
And the connection on the inlet manifold is usually just blanked off if we are talking about the same one, so just connect your boost gauge to there and the jobs a good un
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
