xr dizzy assembly?? help!
Old Apr 10, 2007 | 07:54 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default xr dizzy assembly?? help!
ok ive started putting the engine together, hopefully to be ready for next week :S the dizzy and rotor arm is off the engie, how do you fit it?? so itl fire how its meant to in the right order, and how do u no wich ht lead goes where??
thnx
Old Apr 10, 2007 | 10:47 PM
DROPTOP's Avatar
DROPTOP
bolt it up and adjust it using the slotted bolt holes (turn clockwise or anti) you'll need a strobe to set it properly to 8 degrees iirc. firing order is 4231 iirc ? but might be totally wrong lol best bet is to go to a scrapyard and buy a haynes manual (few quid from there at most) thatll give you step by step instructions or find a cvh in the scrappy and check the leads on that
Old Apr 11, 2007 | 03:59 PM
cosworth_wannabee
nice 1 m8
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
