Cosworth parts Garage clearance UPDATED
I have these parts clogging up my garage
Prices added
Standard 4x4 Front Diff £75
Standard 4x4 Rear 7" Diff £75
4x4 Bonnet £100
170mph clocks showing 99k (ideal for new engine as would show 0000 once run in)
£30
Genuine Beru Plug Leads Only 11k Miles £40
4x4 Thermostat Housing £20
Inlet Manifold (No plenum) £10
4x4 Rear Beam Assembly (Wishbones etc) £80
Brand New 2WD EBC Sport Front Brake Discs (Still in Box) £100
ABS brake Res Pump Assembly £40
Brand New Magnecor Competition 8.5mm Plug Leads In Red £50
4x4 Sump £40
4x4 Crossmember £40
Cambelt Cover £30
2wd Steering Rack Missing 1 pipe
MORE
2wd TPS PF09
4wd TPS PF01
2wd Painted Plenum
2wd Polished Throttle Body
1 Brand New Exhaust Valve
90 Amp Alternator
2wd Prop
Boost gauge in Pod for under Radio
Ford Battery
Will add more as i find it.
Prices added
4x4 Bonnet £100
4x4 Sump £40
4x4 Crossmember £40
Cambelt Cover £30
MORE
2wd TPS PF09
4wd TPS PF01
2wd Painted Plenum
90 Amp Alternator
2wd Prop
Ford Battery
Could you pm me a price on the ecu pls, does it come with chip and lambda sensor ?
I have 803 greens. Is it set for them. And finally I have L6 Ecu currently, I guess I need either conversion spec for wiring or price on loom. (or some other alternative you might have
2wd TPS PF09
4wd TPS PF01
2wd Painted Plenum
can u put prices on these mate
4wd TPS PF01
2wd Painted Plenum
