Focus RS Ongoing Project.
Old Apr 7, 2007 | 10:14 PM
pd689's Avatar
pd689
Default Focus RS Ongoing Project.
2005
OK after loads of nagging, Nash has finally convinced me to do a project thread for my ongoing Focus RS project.
The car was bought standard in Feb 2005 with 18,000 miles on the clock. It was then left alone for four months while I went on holiday to the Falklands.
Some pictures taken when I came back in July 2005.
I intended to keep the car standard, however after a passenger ride in Nath R's Focus RS which was running Bluefin, Mongoose decat and exhaust and K&N Gen II the standard car plan went straight out of the window.
Ford Fair 2005 saw the start of the mods. Superchips London had an offer on the Bluefin. This was installed in the car park and the journey home was worth every penny.
National Day 2005 saw me get a good deal on a Miltek decat and exhaust from Pumaspeed, which Nash used as a pillow on the journey home.
With these mods fitted, the car was superb, and really enjoyable to drive.
November 2005 and i had the car rolling roaded at Emerald, making 255 bhp and 270 lb/ft.
The only other thing to be fitted in 2005 was the Samco boost hoses and Magnecor leads.
Will update this thread with 2006 stuff and more pics tomorrow or monday.
Old Apr 7, 2007 | 10:48 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Nice one
When was you in the Falklands? I was there from 23rd march-1st august
Old Apr 7, 2007 | 11:13 PM
pd689's Avatar
pd689
I was there from the 1st of March to 18th June 2005.
Old Apr 7, 2007 | 11:17 PM
Charlie Chalk
Unknown.
Ah ok... you coming with nasher to APT?
Old Apr 7, 2007 | 11:25 PM
pd689's Avatar
pd689
Yeah I'll come along for a look will have the focus if its back together and the saph isn't ready.
Hopefully the saph will be back or Nash will be a miserable git all day!
Old Apr 8, 2007 | 09:41 AM
MAD EVO 4's Avatar
MAD EVO 4
Old Apr 17, 2007 | 07:06 PM
pd689's Avatar
pd689
First things added were the K&N gen II induction kit, and the creative carbon fibre splitter, this could of been simple to fit, however i had to do it the hard way and this was the end result.
Next up was to get some of the dash flocked and fit my SPA oil pressure / water temperature gauge.
The car was then left due to loads of exercises etc with work.
Old Apr 17, 2007 | 07:18 PM
pd689's Avatar
pd689
The car has been getting loads of attention.
USA rear clusters fitted, which were quite a simple mod to do, just requiring a bit of work with the dremel.
Then the Pro Alloy Air-Air Intercooler kit. The car after the charge cooler was stripped out.
After the fitting.
Throttle body elbow was also painted cheers Nash.
Still to come, brakes, manifold, avc-r and turbo!
Old Apr 17, 2007 | 07:33 PM
love it ,rear clusters make such an improvment
Old Apr 17, 2007 | 07:51 PM
pd689's Avatar
pd689
Cheers, i agree the usa rears do make a difference, don't really like the standard ones after fitting the usa rears.
Old Apr 17, 2007 | 11:34 PM
Charlie Chalk
Unknown.
Some pictures I took at the APT RR day
Good to meet you too
Old Apr 17, 2007 | 11:39 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Lovely mate!
Old Apr 18, 2007 | 09:22 AM
pd689's Avatar
pd689
Cheers for the pics radders. Was good to meet you too.
Old Apr 18, 2007 | 09:25 AM
pd689's Avatar
pd689
I really need to get the pro alloy header tank now as that plastic one looks crap.
Old Apr 18, 2007 | 09:48 AM
Brian's Avatar
Brian
Brian
Old Apr 18, 2007 | 09:50 AM
- Sim -'s Avatar
- Sim -
very nice
any power specs ?
Old Apr 18, 2007 | 09:51 AM
Charlie Chalk
Unknown.
I prefer the standard tanks imo, just change the hoses
Old Apr 18, 2007 | 12:01 PM
Nash's Avatar
Nash
Cake lover!
To late hes already ordered it, asked for something different though we will see if Wayne is willing to do it. All will be revealed when he/if gets it
As for Power its should be around 330bhp once all set up, sure Paul will put it on the Rollers once hes happy with it.
As most people can tell i love this car and love working on it.
Old Apr 18, 2007 | 05:48 PM
pd689's Avatar
pd689
Heres the specs for the new turbo for those interested...
'The “HI Response” Turbo for the focus RS
Manufactured to fit Ford Focus RS 2.0 Turbo – 2002->
Replaces Garrett Turbo – Part No: 722979-0002 – Ford part No: IM506K682AE
Hybrid turbocharger – Part No. MD398
All units are hand built and blueprinted to exacting tolerance for each customers needs.
Specification
1. 52 trim, GT32 specification 71mm high flow compressor wheel.
2. 0.60 A/R high flow compressor housing C.N.C. machined for maximum airflow capability.
3. Left hand thread shaft with GT28 series 76 trim ‘low inertia’ Inconel turbine wheel, fitted with a racing ‘Staggered Gap’ total seal ring to stop oil seepage caused by large bore or low backpressure exhaust systems.
4. Modified bearing housing fitted with angular contact twin roller bearing cartridge for maximum thrust load capability and fastest ‘spool time’.
5. Specially modified turbine housing, 0.61 A/R with ported & polished inlet throat.
6. Optional uprated actuators (any pressure) can be fitted.
7. Compact GT28 bearing housing assembly for optimum water and oil cooling efficiency.
Note. Requires modified oil feed pipe and oil drainpipe. Oil feed adaptor fitting and oil return flange supplied with turbo.
What you can expect for your money!
1. Boost pressure starts @ 2,000 R.P.M.
2. Full boost (limited) 2.1 BAR @ 2,500 R.P.M.
3. No drop in power @ 6,700 R.P.M.
4. Increase in torque and horsepower over the GT17 unit through the entire rev range.
5. A conservative 320-340 BHP potential.
Re-mapping is a must with this unit, as the standard ignition map will not keep up with the fast spool up time of this unit. Performance will vary depending on engine specification such as camshafts etc.'
I'm running actuator pressure only at the moment while i get the mapping sorted, this is 14 psi. At 16 psi on a similar spec car its 300bhp, so mine will be short of this!
Old Apr 18, 2007 | 06:53 PM
tgazvtr's Avatar
tgazvtr
i love this project and all the mods are "just right" for the car! that splitter is amazing!
Old Apr 18, 2007 | 09:39 PM
Stoo's Avatar
Stoo
Interesting read, lovely car
You've obviously put alot of thought into each mod
Old Apr 19, 2007 | 09:31 AM
pd689's Avatar
pd689
Thanks! I've had plenty of time to think about exactly how far i want to go with the car. But its also thanks to this forum and the RS owners club forum, for inspiration.
Theres plenty more to come before i'm finished its just waiting for funds to become available.
Old Apr 20, 2007 | 03:33 PM
T4KAF's Avatar
T4KAF
Old Apr 24, 2007 | 07:47 AM
NathR's Avatar
NathR
Default Re: Focus RS Ongoing Project.
Don't blame me for this mate!
Looking good bud, a very nicely spec'd FRS.
Old Apr 24, 2007 | 10:27 AM
Sticky.'s Avatar
Sticky.
I take it this is Hangar 15 Tuning then
Good work mate
Old Apr 24, 2007 | 11:09 AM
pd689's Avatar
pd689
Good work mate
Yes this is the work of Hangar 15 Tuning, they've done an ok job, but you have to watch out as one of them (Nash) is a right cowboy!
Paul
Old Apr 24, 2007 | 11:13 AM
Sticky.'s Avatar
Sticky.
Old Apr 24, 2007 | 11:33 AM
pd689's Avatar
pd689
In all fairness i actually owe Nash a big thank you for all the help especially when I've been getting pissed off because something won't work and also for all the hours he's put in on a car that isn't his!
Old Apr 24, 2007 | 11:35 AM
Sticky.'s Avatar
Sticky.
He's a top bloke NASH
Old Apr 24, 2007 | 12:03 PM
pd689's Avatar
pd689
Next bit.
Now that the intercooler was fitted, I could start again on getting more power out of the engine, so the next step was to fit a tubular manifold. The standard ford item is pretty restrictive and can free a lot of torque when replaced.
Standard item...
There are a few people making tubular manifolds for the focus rs, however Primary Designs have to be the best with a history of producing exhausts for F1 and WRC teams, i decided on an inconel ceramic coated tubular manifold, not the cheapest but you get what you pay for.
I decided that it would be easier to remove both the manifold and the turbo at the same time, as the manifold to turbo bolts can shear quite easily and the turbo needed to be sent away for modification anyway. Easier to do it all now than have to remove the turbo later for upgrade.
The manifold was wrapped in bubble wrap (to stop it getting dirty) and fitted to the head with a ferriday thermal exhaust plate which is supposed to keep the temperatures down in the head. The plate came with studs and K-nuts which made fitting the manifold easier as there is not a lot of space to get tools into, to tighten the head nuts.
Old Apr 24, 2007 | 02:14 PM
Nash's Avatar
Nash
Cake lover!
It's not a problem bud I enjoy working on yours more than mine tbh, think its probably the fact mine hates me
Old Jun 18, 2007 | 09:31 PM
pd689's Avatar
pd689
Ok some more work.
While I was waiting for the turbo to come back from Turbo Dynamics, the brakes were uprated ready for the power upgrade.
EBC ultimax discs from Performance Stars, Ferodo DS2500 pads on the front, Redstuff on the back and Goodridge Braided lines from GGR.
Once it was back together we still had to push it about the place until this turned up.
Only a baby turbo in the grand scheme of things but gives good gains by maintaining boost higher in the revs.
To fit it the oil feed and return needed to be modified, new hoses were bought for the oil and water feeds and the oil return required the bolt holes to be increased from M6 to M8.
Old Jun 18, 2007 | 10:23 PM
Brian's Avatar
Brian
Brian
Old Jun 18, 2007 | 10:28 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Absolutely love it mate!
Old Jul 12, 2007 | 07:05 PM
pd689's Avatar
pd689
Default Dyno'd today.
Well today was the day, i got to find out the exact results of all the work that has been put into the car by myself and Nash.
Firstly a big thanks to Christian and Gary at APT for fitting the car in this morning.
Flywheel figure and Torque.
Wheel power and Boost.
All in all i'm really happy, its not the biggest power FRS in the world but i'm over the moon with how it drives on the road.
Old Jul 12, 2007 | 09:22 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Fantastic car mate, I really love it.
Old Jul 12, 2007 | 10:10 PM
TimC's Avatar
TimC
absolutly perfectly chosen mods for a road car
Old Jul 13, 2007 | 06:58 AM
- Sim -'s Avatar
- Sim -
hmm for a bigger turbo just so low power?
A friend of mine
stock turbo
1,3 bar
ford motorsport manifold
milltek decat and flexy pipe
denso itv22
bluefin
305 hp / 515 nm
Old Jul 13, 2007 | 11:24 AM
pd689's Avatar
pd689
All i can say is every dyno is different.
Old Jul 13, 2007 | 11:28 AM
Nash's Avatar
Nash
Cake lover!
A friend of mine
stock turbo
1,3 bar
denso itv22
bluefin
305 hp / 515 nm
With that spec i havn't seen a uk car do over 280bhp on any rolling road. Also Pauls car went on a Dyno Dynamics rolling road which are known for being very accurate, he could have taken it else where and got another 20-30bhp if he had wanted.
