GARAGE CLEAROUT, ALL NEEDS TO GO WITH LOADS OF PICTURES
I need to clear some room in my garage to make room for my new car which is coming begining of may.
Old bonnet need prep and paint
Good condition exhaust maifold
K+N missing polished top
Turbo systems chipped ECU. Still has there void stickers over screws and across seals. Was wired in with 2 stage boost. Hearts and Diamonds
Starter motor in v-good condition, Looks pretty new
Ford battery cover
2 new front hoses and one rear, Pair of new rear wheel cylinder
G-Max full suspension kit, Brand new never seen the road, Lowers RS by 20mm, Front springs already fitted
Pair of bonnet vents, all lugs intact and has s/s shield
Good distributor with intact sensor, not a cable tie in sight
Stainless steel exhaust. 2.5" bore with 4" outwardly rolled tailpipe PROV SOLD
Powder coated red 88 spec rocker cover in good condition with polished cross over pipe
Standard intercooler in good condition
Recaro interior 90 spec removed fron an escort cabriolet
90 spec door cards in good condition, Minimal sagging on arm rests, easy fix with some fibre glass
Bad boy bonnet in radiant red complete with vents
Loads of other parts that didnt have time to picture, Try me for what you need.
Ford battery cover
Still waiting for a pm about the front bumper. Fancy a few other items such as the shocks and front recaros. Looks like I need to meet up and collect a few items. Looking forward to hearing from you...
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
krypton
Sep 23, 2015 07:29 PM
